Old 05-16-2005, 09:15 PM   #1
Longstep70
Junior Member
Rear Leafs - are 70's the same as 73's?
I have a 70 with rear leafs and I want to flip kit the rear but I've only been seeing kits for the 73 and up trucks. Will these work or are the leafs different in some way?
Andy
Longstep70 is offline   Reply With Quote
Old 05-16-2005, 09:30 PM   #2
70short/step
70short/step's Avatar
Nope your leafs are wider (or visa/versa). Check with any of the board vendors or ECE. They have the flip kit for 67-72 leafs.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 05-17-2005, 01:45 PM   #3
Longstep70
Junior Member
Are you sure about that? My ECE catalog doesn't have a flip kit for 67-72 and I've looked at a bunch of the vendor sites and found nothing there either. All I've seen is the flip kits for 73 and up.
Old 05-17-2005, 03:19 PM   #4
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
DJM has flip kits for trucks 63-72
63 GMC custom
going to be slammed
kamikazegmc is offline   Reply With Quote
Old 05-17-2005, 07:58 PM   #5
Longstep70
Junior Member
Thank you. I had not checked the DJM site.
Old 05-17-2005, 08:41 PM   #6
72MARIO
72MARIO's Avatar
That's new to me too. I went with a drop shackle and Dearched springs. To get a 5" + drop.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-17-2005, 08:46 PM   #7
Longstep70
Junior Member
How does it ride with the dearched springs? I need to look into that as an option. Did you C-notch the frame?
Andy
Old 05-18-2005, 01:00 AM   #8
kamikazegmc
Registered Smarta$$
how much did it cost to dearch your springs?
63 GMC custom
going to be slammed
Old 05-18-2005, 07:04 PM   #9
72MARIO
72MARIO's Avatar
I have not driven it yet. Should be on the road in the next month at most.
I think it's going to ride really nice. It has to ride better than stock being closer to the ground. I have drop shocks desigend to work with a 6" drop which will also help out.
Just need to find a set of hedders that the collectors wont get ripped off. I have a set of Chevelle shorts but the hit the motor mounts. I am either going to cut the hedders and make em fit or get a set of motor mounts from Norhtwest Auto Fab.
Then finish up th ebrake lines and I can take it for a ride. 4 yearsin the build up I cant wait to drive it !
The spring work costed me $115 Cdn. That included 4 new bushings pressed in. The dearching was like $20 per side. I took them the spring pack in and told them to take 3" out of them. The said no problem.
No notch here.
I have around 3" between the frame and axel and the rubber bumper is about 2" from hitting the frame. The is a member Powell72 he has a 6" coil drop and has 2.5" between the frame and axel and he had no complaints. I personally would not feel good about riding around with a bolt in notch. I would rather smack the rubber bumper off the axel. Mabye this winter I might weld in a C notch but I would want to box the frame in from in front of front hanger to behind the rear hanger.
2005 TAHOE DD
Old 05-18-2005, 08:15 PM   #10
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
i took my truck to Deep South Springs to have my leaf springs dearched. They lowered the truck 4 inches around 2 years ago and i have not had a problem . The truck rides fine but I have not tried putting a serious load in the bed.
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 05-18-2005, 08:20 PM   #11
Super Duck
Chevy Nuttttt
Super Duck's Avatar
I just put a 75 rear end under my 67 and welded new spring mounts on the bottom of the housing. no kit req just a torch and a welder.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 05-19-2005, 06:42 PM   #12
72MARIO
72MARIO's Avatar
I think that Dearching the springs would show the load alot sooner than with the stock contour.
2005 TAHOE DD
