Old 05-19-2005, 12:24 PM   #1
dapolice1
We can roll all Day!!
1/2 ton crossmember in 1 ton
Guys can I install a 73-87 1/2 ton crossmember into my 84 dually and just use the dually suspension? The crossmember has tubular arms so will the 1 ton spindles and brakes bolt up to the 1/2 ton arms and crossmember?
dapolice1 is offline   Reply With Quote
Old 05-19-2005, 02:37 PM   #2
bodydropped
i dont see a problem but the x memeber i believe is the same maybe beffer but the lowers r different that i know of because they have a different bushings
bodydropped is offline   Reply With Quote
Old 05-19-2005, 02:41 PM   #3
86 GMG
That Is A Good Guestion My Opinion Would Be The Croosmember Will Work Fine But The Arms Wont Due To The Diffrent Sizes Of Ball Joints Etc. But Lets See What The Others Say As Well Good Luck As For The Tubular Arms If They Dont Work Can I Buy Them From You?? Or Maybe Swap With You A 1 Ton Crossmember And Arms ???
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 05-19-2005, 02:46 PM   #4
86 GMG
Oops I Forgot To Say My Father In-law Has A Wrecked 1 Ton Damage Was In The Front But To The Best Of My Memory It Was Mostly Cosmetic Damage.
