Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-26-2005, 12:12 AM   #1
plumbcut
california fill
any chainsaw/small engine experts?
I inherited a 25-30 year old craftsman chainsaw and ive got it torn down to clean it up.. well I cant get the clutch off the crank (its left handed threads).. any ideas?
anyone know of a good source for vintage chainsaw parts? ignitions, clutch, stuff like that? I think I found a place w/ a carb kit already... thanks!!
plumbcut is offline   Reply With Quote
Old 05-26-2005, 12:37 AM   #2
Stingray42
Woot.
Stingray42's Avatar
ebay!
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 05-26-2005, 05:59 AM   #3
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
my guess is to put a wrench on the flywheel side and then make a fork type tool with a 90 deg. bend just past the forks to slip in those holes shown and give it a little persuasion from a good sized BFH and see if it'll come loose. hopefully those theads aren't too rusty.
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 05-26-2005, 06:23 AM   #4
curbyk
69 C-10 project
curbyk's Avatar
Try contacting sears at the local store first, if no luck there try the corp. level.
Good Luck.
69 C-10 Work is complete
curbyk is offline   Reply With Quote
Old 05-26-2005, 08:33 AM   #5
smirch9
try PB Blaster, it'll bust loose anything..You can pick it up at your local parts store.
smirch9 is offline   Reply With Quote
Old 05-26-2005, 11:31 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Maybe a strap wrench will work.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-27-2005, 08:19 PM   #7
plumbcut
california fill
all very excellent ideas- but Ive already tried all of those! PB blasted the heck out of it..
I tried putting a fork like tool in those holes.. I used a small pair of long nosed vise grips and then put a wrench perpendicular to that.. it held real well... with my dad turning the wrench and me holding the flywheel on the other side as best as I could (its very soft aluminum), we couldnt muscle it loose (and we're not girly men ) I think I need to modify a big 1/2" drive socket to fit in there so I can run my impact on it... as for the strap wrench--- the outer part of the clutch spins freely (its the part that the chain rides on) so it would be useless.. I did use a vice grips chain wrench to hold the flywheel side though...
sears wants nothing to do with this saw anymore and cant recommend any parts providers.. their website however does have nice exploded views of any and all parts....
Im hoping I dont wreck this clutch because I dont know if Ill be able to replace it but i sort of NEED it off.... Ill keep ya'll posted thanks for the ideas!
pc
Old 05-27-2005, 10:23 PM   #8
3 on the tree
Poulan has made the Sears chainsaws for quite a few years. I would check that out to see if it is a Poulan saw.
3 on the tree is offline   Reply With Quote
Old 05-28-2005, 12:17 AM   #9
chipflyer
chipflyer's Avatar
When I worked in a saw shop we had a special tool that was used just for removing clutches. It was a piston stop, you removed the spark plug and screwed it in. It was basically a long threaded bolt (about 2 inches) and it would stop the piston from coming up which keeps the crank from turning. The tool we had was a Stihl or Huskvarna special tool but one could easily be made. It is the only way to properly remove clutches that I know of and works well on any brand.
jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
