05-31-2005, 08:50 AM | #1 |
Gauge/Bezel Question
What's the scoop on instrument gauges/bezels? I have a 1980. Are all 73-87 interchangeable?
05-31-2005, 09:13 AM | #2 |
yes they are all interchangable but you will find a little difffrents in the windshield wiper/washer knob are diffrent on a few years some trucks had them on the turning signal and some were in the dash
square body trucks an addiction or an investment either way they consume all my extra time and money |
05-31-2005, 09:25 AM | #3 |
Happy to be here
NO, they are not "all" interchangeable. Although they will fit, that does not mean they will work. I'll have to post the details later since I'm trying to leave my office now. There are quit a few changes made through the years at are very important....
05-31-2005, 09:51 AM | #4 |
Looking fwd to reading about those differences N2Trux. BTW- Nice truck!
06-02-2005, 09:09 AM | #5 |
The bezel will vary a little based upon whether the truck had A/C or not (has to do with the vents), was in a year with the wiper control on the dash or on the column, had brushed aluminum, woodgrain, or was plain. Note that The brushed aluminum and woodgrain are basically factory appliques (stickers) over the base model bezel.
The LMC catalog actually does a pretty good job in showing the differences over the years. Good luck!
Semper Paratus |
06-02-2005, 09:15 AM | #6 |
I sort of felt that KShortell...but just wanted to make sure before I spend the big bucks on a new brushed alum one for my truck.
Thanks for the reply. |
06-03-2005, 02:17 PM | #7 | |
Semper Paratus |
06-02-2005, 12:40 PM | #8 |
www.73-87chevytrucks.com
The aluminum is cover is split 73-77, 78-80, 81-87.
They are listed here, but the pic is the same for simplicity. http://www.73-87chevytrucks.com/merc...tegory_Code=7G
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-02-2005, 01:00 PM | #9 |
Yea, that's what I'm talking about...they all LOOK identical, but for some reason they are split up between the years you've listed. Thanks Capt.
06-02-2005, 01:18 PM | #10 |
yeller
The only real difference is the diameter of the gauge openings. I believe LMC has their diameters in their catalog. If you are going to put in aftermarket gauges, get the one with the largest openings. They still won't be big enough, but you still have less to trim off.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-02-2005, 04:19 PM | #11 |
1980 chevy sorry for the miss leading i just learned something myself today. boy those ele. gauge set really would look sweet in our trucks wouldn't they anyway have a good day
06-02-2005, 04:23 PM | #12 |
No worries 86 GMG, that is what is cool about this site..we all learn something every now and then....there are all kinds of parts that are soooo close, but for one reason or another may not bolt in. I have the same questions regarding front grilles. I really like the older ones....and they look close, but just not sure if the bolt holes are in the right place, etc...
Thanks for the info bigblock73...I'll keep that in mind. |
06-02-2005, 07:56 PM | #13 |
To clarify, the trim plates ARE different, I just listed on pic for each piece. Jeff listed the actual difference which is the diameter size.
06-02-2005, 09:35 PM | #14 |
North Coast, baby!
I put a 77 bezel in my 79 and it fit about 90% correct. It had clearance issues on the lower side of the bezel and the lower column covers did not interchange. As stated earlier, they can be made to work but it will look a tad off. Ended up buying a used correct year for my truck (78-80) and am alot happier.
Brad 79 Scottsdale C20 350/350 3.73's Still running full CA smog gear! |
