06-01-2005, 04:31 PM | #1 |
Life, Be In It.....
Will these fit????
I have a 68 five lug, will these Chevy 5 lug rims and tires off a 1995 Chevy Truck fit?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 06-01-2005 at 04:31 PM. |
06-01-2005, 04:58 PM | #2 |
I'm assuming your 68 has had a drum to disc conversion and has 5 on 5 pattern. If this is correct then they will fit.
None of the 68 trucks came stock with 5 lugs... Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
06-01-2005, 06:21 PM | #3 |
Chevy Nuttttt
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell is there anything else? |
06-02-2005, 05:53 AM | #4 |
better check backspacing also. I had a newer style wheel and tire for a spare and didn't know it wouldn't work until I had a flat and went to put the spare on and the tire bottomed out against the bed before the wheel touched the hub.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! |
06-04-2005, 11:25 AM | #5 |
I'd jack your truck up and try to put them on. It'll take like 10 minutes,, maybe 20 if you have a helper. Then you'll know for sure, right?
I got a bench seat baby, you don't have to sit over there. |
