Gauge cluster Question
Hi there guys, This is my first post,
I cant remember who posted this link the other day but I bookmarked it . It should help you .
http://www.73-87.com/7387garage/garage_interior.htm Try that . Frank |
gauges
HELLO,,been working on same thing myself... on the 73-87 parts board there are 2 setup's for sale,,one automatic,one not (or floorshift).. ONE is from (63chevemall) the other is from (SassyChevyChick).. might wanna check them out and talk to those two..
Thanks frank, that helps alot, but i was wondering, if i get a newer cluster from a 79, and i get a circuit board for my year of truck, would i have to change the wiring at all? would the gauges still work other than the oil pres?
North Coast, baby!
According to what I know about this subject, putting a volt gauge pack (79) into a amp gauge truck (76) will result in a meltdown.
Brad 79 Scottsdale C20 ![]() 350/350 3.73's Still running full CA smog gear! ![]() |
i dont have a amp gauge....76 was the first year of the volt gauge
What do we get for $10?
I think that if you had a '78 or later tach cluster you could swap in your current mechanical oil gauge and stick in a '76-'77 circuit board in it, and it would work. It might require some modification to the cluster housing, but I think it could be done.
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ![]() Last edited by 77gmcjoe; 06-03-2005 at 12:30 AM. |
#8 | |
