Old 06-04-2005, 03:34 PM   #1
Scooter67
vent rubber question (pics)
Is the bottom edge supposed to tuck down inside the door? Just installed new vent rubber and no matter what I do it won't lay flat against the door. Old vent rubber was like this too.
Scooter67 is offline   Reply With Quote
Old 06-04-2005, 04:00 PM   #2
jhow66
jhow66's Avatar
Inside
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-04-2005, 10:50 PM   #3
kaycee
kaycee's Avatar
I put mine on the out side they fit pretty good this way it didn't make since to have them run inside and let the water get inside door.But if mine came out like that I would put them inside.OH well I tend to do things different
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 06-04-2005, 11:54 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
they go inside, the small amount of water that might go thru will drain out the bottom drain holes in the door
kelsfine69 is offline   Reply With Quote
Old 06-05-2005, 11:28 AM   #5
Scooter67
Went ahead and tucked it in. Looks alot better. It makes some contact with the outer door, so hopefully won't let alot of water in the door. Betcha the rubber that came on the truck was wide enough for a good seal! It can be hard to find aftermarket stuff as good as original.
Old 06-05-2005, 06:36 PM   #6
Yukon Jack
Yukon Jack's Avatar
Much better!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
