06-06-2005, 12:17 AM | #1 |
YES_____NO
What radios fit without cutting dash
What radios will fit 67-72 chevys without cutting the dash?
It can be after market, from a car, or differant year ect.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
06-06-2005, 03:58 PM | #2 |
Try Custom Autosound
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 08-30-2005 at 11:58 AM. Reason: update link |
06-06-2005, 07:40 PM | #3 |
Blank
other than going with custom autosound. factory radios from car of the same era with two post and aftermarket radios with two post can fit but will live a small gap above and below the radio because the trucks radio for some reason was a little taller
06-06-2005, 08:55 PM | #4 |
Got Light Emitting Diode?
van radios fit perfect
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
06-07-2005, 03:46 PM | #5 |
Questionable
If you want aftermarket, here's a cheap solution:
Go to the auto parts store and find a shaft-style radio. To add MP3 support, get a USB memory stick and add this for $30: http://www.walmart.com/catalog/produ...51254022592401 It plugs into your cig lighter and plays songs stored on the USB memory stick over the radio waves. You tune your radio to the right frequency and it lets you listen to the stick. Just remember, if your MP3's are lower sound quality, it's going to sound like crap. This is a decent sub-$150 way to play MP3's in our trucks without cutting the dash and it requires no special wiring or knowledge. If you can install a stereo, you're good to go.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
06-07-2005, 03:54 PM | #6 |
YES_____NO
Cool thanks for the replys guys
06-07-2005, 03:58 PM | #7 |
Questionable
PS - when I say auto parts store, Pep Boys is mainly who I'm referring to, They have the Audiovox and Rampage lines. Crutchfield.com has the Sanyo MARB---- (I forget the numbers, just look at the Sanyo Cassette radios).
06-08-2005, 03:47 AM | #8 |
Try searching for "shaft style" AM/FM cassette deck or CD deck (if there is such a thing as a shaft style CD deck). Just put a car audio brand name in front. I found one by Kenwood:
KRC-2007 Only 15w RMS, though, and I couldn't see if it has CD changer control outs. There are Sanyo shaft-style decks all over the place.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
06-08-2005, 02:39 PM | #9 | |
Questionable
"THIS ITEM IS NO LONGER AVAILABLE."
06-08-2005, 02:43 PM | #10 |
Kenwood also made a shaft type radio cassette. I went with the FM type cd changer when I had mine and it worked quiet well.
06-08-2005, 02:49 PM | #11 |
Just found this one at caraudioexperts.............
http://www.caraudioexpert.com/produc...productID=1786 |
