Old 06-06-2005, 10:03 AM   #1
Custom 68
Custom 68's Avatar
new wheels on old truck question
I have some wheels I ran on my 96 Tahoe I would like to run on my 68 both are 6 lug but my hub in larger (3.5 vs 3 inch) on the 68, do you run a spacer if it will fit or have them machined or what? The backspacing on teh new ones are 4.5 I think the wheels are just 8 inches wide.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-06-2005, 10:18 AM   #2
kwmech
The only issue is the back spacing, the rim or the tire itself may hit or rub on something. You'll just have to bolt them on and cycle the steering wheel back and forth.
Old 06-06-2005, 06:00 PM   #3
I would not run a spacer. If you like them I would have them machined out. If it is a 4.5 backspace you are probably OK. If they are factory wheels they will be 7". I don't know of any fatory 8" wheels from the later models.
I don't like spacers, I have see to many folks lose wheels because of spacers.
Old 06-06-2005, 06:12 PM   #4
SCOTI
SCOTI's Avatar
I tried bolting a set of stock 6-lug aluminum late model wheels to the '67 rolling chassis I have on my trailer & they would not fit the front hubs. I had to space them out @ least 1/4" & then the studs were too short for the lug nuts to thread more than a couple of turns.
The backs fit w/o issue.
Aftermarket wheels might have a different diameter (larger) center bore & might not be a problem.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-06-2005, 08:46 PM   #5
70 longbed
I would not use spacers either. You can buy adapters, bolt onto your existing hub, and then the new wheel bolts on to the adapter. The center hub needs bored out for the size of the older hub, but your local machine shop should be able to handle that for you.
There are some older threads on this topic, just not sure how to find them.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 06-07-2005, 09:14 AM   #6
Custom 68
Custom 68's Avatar
Thanks guys, I figured there was some old posts but didnt know how to find them either. They are aftermarket American Racing I had on my Tahoe I sold it but kept the wheels (my folks put them on their Blazer) anyway I measured the hub diameter and found it wont fit I might do some checking on machine work I dont knwo if it would be worth it or not.
Dave
Dave
