![]() Join Date: Mar 2004
Please help w/ motor size
I have a v8 in a 69-70 GMC 1/2 ton I'm parting and I need help trying to decide what it is. The #'s on the block aren't listed in the book I have. The # on the back of the block is: 10066038 and on the front of the block by the head it is: MAI 9353. The glove box door list it as a 296 v8 which I've never heard of. Thank's in advance, Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) Last edited by 4bynut; 10-04-2007 at 09:31 PM. |
My best guess is that it's a mis-print on the decal, and the engine is actually a 396 big block.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
10066038...350.....92....4...Goodwrench crate motor, 2-piece rear
seal, "Hecho en Mexico" http://www.mortec.com/castnum.htm Last edited by Randy70C-10; 06-11-2005 at 10:35 PM. |
Here's what I dug up from my info on the casting number from the block....10066038...350.....92....4...Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
Looks like the motor probably was swapped out at some point in it's life. |
Thank's for your help guy's. I really appreciate it. Do you know if them are good. I seem to remember hearing something about problems with the GM motors from mexico. But I don't know if it was just certian years. Also would it be a four bolt main block? Thank's again Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
Mortec lists the engine as having 4 bolt mains.
Jim |
The Mexican engines were called "Targetmasters". They were built with some heavy-duty parts and put together quite well. You shouldn't have any problems with that engine.
