Almost done: Not too shabby
For a driveway paint job, didn't come out too badly (nothing close to some of the stellar rigs on this site, but it is a daily driver, so I didn't put a huge amount of effort into it).
Only thing is the gap between the new cowl hood and the new fenders. I have tried everything and I can't get the hood down any more than it is.... ![]() Anyways, now the 99 suburban drivetrain is in and complete, and the body is done (except the side moldings....I want to buff it up a little before installing), and I need to put in the bed coating, and install the tonneau. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
Looks good, Have you tried a different set of spring and or hinges? The springs get weak and the hinges get a little sloppy and viola a jacked up hood w/o the use of air shocks. Just a thought and fairly easy to fix. Harold
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks like a pretty good job to me... Nice work..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Old School, New Style
If nothing else it's a great 10 footer and awsome daily driver. I have seen some bad driveway paint jobs but not in this case. Looks good.
Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck Last edited by Long Roof; 06-12-2005 at 06:32 PM. |
Thanks guys. I think I will spring for a new set of hinges.....maybe slot the holes a bit more too. I forgot to post one more picture. I filled the hole for the filler for the in cab tank (now sitting in the driveway).
Welded in sheetmetal that I hammer and dollied into shape: ![]()
chevelito
great looking truck. paint looks great!
Jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
More Cowbell....
Looks might fine to me. Great work on the filler removal.
Oh, and TWO THUMBS UP on the seat choice!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#8 | |
As for my hinges: They do have a little slop in them. I hammered the rivets to take some of it out. I think I need to slot the 3 mounting holes a good bit. I will get a set of Genuine GM units from Brothers Trucks and slot them a bit. My springs are still good.
Thats the Hillbilly way
Tim; Looks Great , the slider looks good back there also.
![]() You sure got that done pretty fast Great work.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Well....installed the new Genuine GM hinges today, and the hood now lines up beautifully.
All that is left to do now is to install the tonneau cover and eventually get the AC from the L31 suburban all plumbed up. Am I just a complete sissy boy, or do you guys also get anxious when driving a vehicle after a conversion and extensive mechanical work? I am starting to put mileage on the truck now, and I am a nervous wreck......and it happens after every conversion I've done.....I should be used to it by now, but I guess not....... I keep going over the whole process.... --Did I tighten every bolt --Did I do everything I needed to --Are all the clearances correct --Is the donor drivetrain in good shape --etc etc etc Think I am a pansy? ![]()
#11 | |
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
Gm still sells the hood hinges. Try lubing them up first. I would advise not buying repo hinges. Tim Christian will not even sell them last I talked to him.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Designated A-hole!
Looks good!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
With the seats installed did you gain any extra room. Leg or head room or is it about the same? It looks great. My problem is that i am 5' 20" tall and room is at a premium. Just wanted to know if it helps I am in.
#15 |
Sorry.....
Nice looking truck!!! |
#16 |
#16876
Just curious, Are you going to paint the upper door frames white? Looks like you did a good job. Just wait til the trim gets back on. Thats when it will really start looking good.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#17 |
Ya know, I messed up in 2 places. One was the window frames on the door. It only dawned on me after I has it all back together, and it didn't seem worth the trouble to rebuild my spray booth and take everything apart for that.....I also painted the bottom of the tailgate Ochre and it should have been left white....oh well! It isn't a show truck (obviously) soI am not too concerned. Here are the pics with all the moldings back on:
http://67-72chevytrucks.com/vboard/s....php3?t=160688 As for the seats, I gained leg room as I pulled the in cab tank and installed the seats as far back as I could.....
#18 |
How much room do you think you added by doing this? Just a "guesstimate" would be fine
#19 | |
From the middle of the seat cushion to the headliner (vertical measurement):34" From the front of the seat cushion (which be behind your knees while seated) to the dash: 14" From the seat back (where the small of your back would be, or your 'plumber's smile') to the dash: 34" ....that do it for ya?
#20 |
![]() Join Date: May 2002
Tim240Z:
Could you post the GM part number for the hinges? I tried a couple of GM dealers in Nashville from time to time to get parts...most of the time I get that "Why you get a late model truck so I don't have to page through this old dog-eared parts manual look". Thanks! Jim Mt Juliet |
#21 | |
Wes can be reached at 888-338-2502.
#22 | |
#23 |
More Cowbell....
Mine were '98 Suburban second row....as seen above!
#24 |
![]() Join Date: Apr 2005
I know it sounds "tacky", but you could spray bomb the window frame and no one would be the wiser.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#25 |
MOVE OVER
Looks Great!!
No matter where you are..... There you are... Buckaroo Banzi |
