06-14-2005, 02:00 PM | #1 |
Nothings as cool as my 72
Ls-1
I was thinking of putting an LS-1 in my 72. Would it be harder to put in then a normal 350. Do the motor mounts on the engine in the right place to mount in my truck. Does the engine blot right up to a TH350. And is the wiring really hard to do if I go with a carb.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
06-14-2005, 02:13 PM | #2 |
Mounting points are completely different to the older SBCs. Don't see the point in using a TH350.....buy the LS1 as a package with the 4L60E and get the overdrive. Putting a carb on an LS1 would also be kinda pointless.....the beauty of that engine is its engine management system. The wiring is not difficult to keep the injection.
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
06-14-2005, 02:22 PM | #3 |
Questionable
There are a set of LS1 mounts that you can purchase for our trucks as I understand it.
There is a very long thread about this subject in the FAQ forum.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
