Old 06-21-2005, 06:15 PM   #1
Green Machine
Green Machine's Avatar
New windshield, New rubber gasket, Doesn't fit !!!
I have a 1968 C10 Custom with the trim moldings in the front and rear glass. Went to body shop today, paint is done and he had front windshield and rear glass installed. I bought new rubber gaskets for both ends from LMC about 5 years ago when I installed rear slider. Reused rear gasket and it fit fine now and before. Bodyman bought new windshield and used my 5 year old, new in package rubber gasket to install. I noticed that the gasket did not set flush with winshield frame on either side post. Top and botom seem to fit well. I pointed out the problem and we both messed with it for about 30 minutes, but no real improvement. I questioned him about the install, and he said he put rubber on the glass, put trim in the rubber and installed assembly into truck. That is the correct sequence, right ??? I know it will leak like crazy and must be fixed, could it be the glass (had made in Mexico sticker on it), or do I need a different rubber gasket ? Part number on package is supposed to be correct for 1968. Anything else to check ? What could the problem be ??
My bodyman (30 years experience) and I are both stumped (and want to get this finished) HELP !!!!
BTW truck looks awesome.........will post pics when I get it back, Thanks
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-21-2005, 06:40 PM   #2
Jwill41
Jwill41's Avatar
I am not sure but it seems to me that the trim would go in last
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 06-21-2005, 07:21 PM   #3
Smitty
Smitty's Avatar
The stainless that surrounds the glass can be different. The leg of the extrusion for lack of a better word that fits into the rubber molding differs
in some of the later years. So it could be that the gasket is wrong. Ran into this problem with my brothers '71 and an aftermarket rubber. Went to chevrolet a little more expensive, but they had the right application to the year rubber!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 06-21-2005, 07:42 PM   #4
BAD4X4
BAD4X4's Avatar
There is a short lip moulding and a long lip. All the new aftermarket moulding should take both. I know this because my buddys dad owns a classic auto glass shop. Hope this helps.
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 06-21-2005, 10:02 PM   #5
Green Machine
Lmc lists two different numbers 67-70, and 71-72, I have the correct number, atleast on the package. I don't think that is the problem as the trim sits in there ok, but I could be wrong, what would the symtoms be if you tried to put 68 trim in a 71-72 rubber ? any thoughts appreciated.
Old 06-21-2005, 10:11 PM   #6
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
I just had new front glass put in my truck at a shop. It take 4 guys, four hours. Big pain in the butt, glad I didn't do it at home.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 06-21-2005, 10:13 PM   #7
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The 67-70 trim is shorter than the 71-72 trim, just so it makes more sense. If you try to put the short trim in the deep gasket, you should be able to just pull the trim out I'd think, but I'm not a windshield guy so I have no idea.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-21-2005, 10:39 PM   #8
Green Machine
Yep, and if you had 71-72 trim in 67-70 gasket, it would stick way out. I dont think that is the prob. Has anyone got a bad gasket or funky windshield before ? Who besides GM, what board vendors might have a tried and true gasket for that ? Or do I just have to pull the sh1t out of it towards the inside to get it to hook ?
Old 06-21-2005, 10:41 PM   #9
72MARIO
72MARIO's Avatar
I have heard that it's possible to streach the gaskets out. The truck shop I deal with had a complaint from a glass shop because the gasket was to big. He simply sent him a new one and told the glass guy he streached it out. Not sure if that helps you out any.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-21-2005, 11:15 PM   #10
71RestoRod
71RestoRod's Avatar
I'll relate my latest windshield install experience...
I had a local shop come to my house to do the install. I adamantly suggested that they send one of their most experienced guys to do the install, not someone that only knows how to work a caulk gun. Some kid shows up by himself. Of course he brought their standard replacement windshield (made in China or some such thing...) I helped him for three or four hours and there was just no way that windshield would go in. I didn't know if it was because he didn't know what he was doing or if it was the gasket or what (also an LMC gasket purchased several years ago). He left with the windshield half installed...
I was ordering a couple of parts from Rick's that week anyway, so I asked Shawn to throw in a new gasket (sorry, can't remember the manufacturer). The installation shop came back a week later. Go figure, this time two guys showed up with a nice quality PPG windshield. This one with the new gasket went in like butter. In my case, I know it was a combination of the crappy glass and LMC rubber, but I suspect it was mostly the glass. Dimensionally, it just wouldn't clear the windshield flange with the gasket in place. I had cleaned up (ground down) the flange really well too.
You absolutely need to set the trim before installing the windshield. Also, don't just rope it from the bottom all around to the top... you want to work your way out to the top corners or you'll get wrinkles.
Here's a good link with some tips:
http://67-72chevytrucks.com/vboard/s....php3?p=954930
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 06-22-2005, 11:11 AM   #11
rickspickuppart
The seal was made by precision, a few years ago we had some problems getting other brands to fit correctly but then we started using precision's stuff we havent had any problems since.
Shawn
rickspickuppart is offline   Reply With Quote
Old 06-21-2005, 11:32 PM   #12
Green Machine
Thanks 71RestoRod, would you care to elaborate on just what didn't fit where ? I don't quite understand yet. Did you happen to examine the gaskets and see any difference ? Thanks
Old 06-22-2005, 12:47 AM   #13
jostrans68
Jostrans68
jostrans68's Avatar
I had mine put in a week ago By a board member that works for a local glass co.. I had a seal I purchased from Wes about 4 yrs ago... he showed up by himself i was concerned except fot the fact he owns one of these trucks...it took hmi about 30 minutes and it was done...Mine had no trim though....
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 06-22-2005, 01:11 AM   #14
71RestoRod
71RestoRod's Avatar
I did inspect the gaskets closely. I couldn't see any difference as far as the shape goes, but the new one did have a better "feel" to it, being more pliable.
It seemed to me that the windshield was just too large all around. We tried seating it from the top and roping down, and seating at the bottom and roping up... nothing really worked, but it was so so close. It was very frustrating. The gasket would deform so much while setting the glass that the trim would just pop out.
When you install the windshield, you have to "slap" it to get it seated completely. As you slap, the gasket sort of rolls into place around the flange on the windshield frame. It was as if either the glass was too big to allow the gasket to seat into place (rolling around the frame), or the gasket was too big. The gasket is rubber and gives... so I'm of the opinion that it was the windshield that was causing the trouble. Apparently, so did the installer, given that they returned with a much better quality windshield. I had the first glass sitting there for over a week. With the cheap glass, it looked to me like I could see flat spots and distortion. Looking through the PPG glass is like there is nothing there at all. I probably would have reused the LMC gasket, but the installer had ripped it in a couple of places while trying to force it in. After the first fiasco, I just wanted a fresh start because the new trim was starting to take a beating.
As far as cleaning up the flange around the frame, there were places where the factory pinch points were kind of sloppy. When I did the body work on the truck, I cleaned up the windshield frame really well and evened out any protrusions and rough spots where the gasket sits.
Old 06-22-2005, 10:50 AM   #15
1-PU70
1-PU70's Avatar
There are only 2 mfg of gaskets to use GM and Precision. Anythin else and your just wasting your time.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-22-2005, 10:53 AM   #16
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Use "Precision" brand gaskets. Trim goes in then gasket then rope. Use masking tape to hold the whole shebang together. Install. I went from bottom to top. working evenly one side to other. then remove tape.
Pinch weld comment is accurate observation. I did not grind my defects down and the gasket over it was not as pretty as everywhere else. Was not so bad that it leaked. It is not so noticible now that the weather has turned hot.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-22-2005, 11:46 AM   #17
Maximum Overdrive
December 21, 2012
If you have the old windshield still, measure it and compare it to the new windshield.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 06-22-2005, 12:24 PM   #18
70c10
67-72 Addict!
70c10's Avatar
I can also vouch for the PPG glass because my 70' has it. When my dad had his windshield done, they used a no name glass and an aftermarket gasket that wrinkled up in the inside corners. Recently I had a windshield place install a new windhield in my 71' but I reused a GM gasket I had and it turned out much nicer.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
