Old 06-20-2002, 01:00 AM   #1
Blue_71
Bloo
Blue_71's Avatar
compression, are these numbers good or bad?
checked 7 cylinders today, couldnt get to number 6 because of the danged header...
cyl|lbs/sq.in|plug|gap
1|115|wet|40
2|155|wet|40
3|135|wet|40
4|132|wet|40
5|125|wet|40
6|n/a|wet|40
7|130|wet|40
8|130|wet|40
notice those are in square inches, is the like 9. numbers square feet? and how could i be getting too much gas in the cylinders? thats what i was told as to why they were wet (showed them to my grandpa who has worked on cars 60+years and thats what he said)
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 06-20-2002, 01:10 AM   #2
Gee_Emm
The main thing to look for in compression readings is the difference between the numbers and how they could be related to a problem. Shouldnt the wet numbers be higher then the dry?
Gee_Emm is offline   Reply With Quote
Old 06-20-2002, 01:12 AM   #3
Gee_Emm
Oops I read your chart wrong. Did you take "wet" readings, as in putting oil in the cylinder then taking the reading after you take the dry readings?
Old 06-20-2002, 01:14 AM   #4
Blue_71
Bloo
Blue_71's Avatar
lol, i dunno, all 8 were wet, i was just trying to find out my compression, and then i discovered the wet plugs, which i doubt have less then a mile on them. (just moved truck around yard)
and the thing about getting too much gas, how do i get rid of that?
the cylinder wasnt wet, that i know of, i just took the plug out and screwed the tester in and turned the motor over a few times.. it was the plugs therselves that were wet when i took them out
1989 Chevy K2500
Old 06-20-2002, 01:26 AM   #5
Gee_Emm
No I was actually referring to doing a wet test by squirting oil into the hole. I have no idea why your plugs would be wet, sounds wierd. Try doing a google search for a website that explains the compression testing process, you would get alot of good info in one spot that way.
Old 06-20-2002, 10:01 AM   #6
johnnyp
Keepin' It Stock
johnnyp's Avatar
Numbers aren't too bad for engine with some miles. I think stock numbers are in the 150-155 range. The main thing is they should all be close - # 1 is the one out of line. If you do the test again, using the wet method (pour couple of tablespoons of oil in plug hole) and you get higher numbers, then it's rings/cylinder. If numbers are same, then it's exhaust leak, possibly valves.
If the plugs are wet with gas, then your carb may be leaking gas from the bowl - could be bad plug in bottom of bowl. Whatever is causing the plugs to get wet needs to be address ASAP - gas mixing with the oil is a very bad thing.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 06-20-2002, 10:41 AM   #7
Blazer1970
Blazer1970's Avatar
Did you have the throttle open when you were cranking the engine for the compression tests? If not, it will suck fuel through the idle circuit, and since there is no spark, it just gets sucked into the cylinders. It (throttle closed) will also affect your compression test a little, but it will just show lower compression across all cylinders, so it does not matter if you are just comparing to see if they are even.
Blazer1970 is offline   Reply With Quote
Old 06-20-2002, 10:56 AM   #8
hanssolo
hanssolo's Avatar
The uniformity of the readings are more important than the actual readings, unless they're all real low. Hotter camshafts will bleed off compression at cranking speeds also so I think its normal for those to be lower. i.e. more overlap.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 06-20-2002, 04:32 PM   #9
Blue_71
Bloo
Blue_71's Avatar
so oversized cam will make the readings lower? i was told when i bought the motor that it had a big cam in it, not like huge but a little over stock.
throttle was closed, so i need to do it again open?
i was told quadrajets are bad about leaking gas, so im goign to check that out in a few minutes
would having open headers on it mess with any of this? the open headers is why im not positive about the cam being over stock
1989 Chevy K2500
Old 06-20-2002, 06:20 PM   #10
WB72
Before and After
WB72's Avatar
Having open headers will Not affect the readings. If the readings are more than 10% different, there could be problems with your valve seats or rings.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
