06-23-2005, 10:16 PM | #1 |
pulling the body off: Worth it?
I have the whole suspension rebuild kit from Early classic. 2/4 lowering kit and front end rebuild kit.
I really want to pull the body so I can blast and paint the frame and trailing arms, a-arms etc... should i pull the body? how long will it take? this is a 72 suburban and is a daily driver. but I could go without it for about two weeks.. is it worth it or do any of you have any better suggestions? |
06-23-2005, 10:37 PM | #2 |
Put it up on jack stand, pull wheels off, soak it with your best grease cutter, pressure wash it, let it dry, shoot it with some semi-gloss black, put her back on the road!! JMHO.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-24-2005, 12:59 AM | #3 | |
I agree with Hart_Rob. I use condrete driveway cleaner from Costco. I recently sprayed some on teh A-arm of my S10 and let it sit for 2-3 hours. When I washe dit off the paint was gone. I also did it on the frame where the steering box is and it removed the paint. I used it l strength applied with a spray bottle. This stuff cuts grease better than anything I have ever used. Tim
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-23-2005, 11:01 PM | #4 |
its all about the +6 inches
2 weeks is kinda optamistic IMO... if you could put her under longer, I'd say go for it, but with your time table, I'll have to agree with Rob.
06-23-2005, 11:08 PM | #5 |
hmm.... I own a good pressure washer....
what flavor rattle can paint is the best? |
06-23-2005, 11:36 PM | #6 | |
Weekend Warrior
If you have a spray gun I would go with a couple of quarts of Rustolem - "Satin Black" and thin it with a little Acetone. It goes on pretty nice and I like the way it looks. 2 or 3 quarts should be enought to do the frame, springs, rearend, control arms etc. etc. and it's less than $50 for 3 quarts and a gallon of acetone. (you can also buy it in rattle cans if you want) That is what i did on my ride (although i did take the body off, I just couldn't affort to blast it (time) and powdercoat it ($$$$)) You can see pictures @ the link in my sig if you want. just type "654321" into the field that asks for a VIN I also Painted my Radiator Support and Inner Fenders with it. - most of the pictures of this are @ the bottom of the page when you log in
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 06-24-2005 at 12:13 AM. |
06-24-2005, 01:13 AM | #7 |
the only other thing I failed to mention before is that I also have a new body mount kit that I want to install also, this is why I was thinking just go ahead and pull the body off...
06-24-2005, 01:20 AM | #8 |
A body off resto on a burb is a small act of congress without a lift. The body can be unbolted than jacked up one side at a time to put your body mounts on. POR15 is pricey, but the best coating for a rusty frame.
06-24-2005, 08:49 AM | #9 | |
67 is sold
06-24-2005, 01:20 AM | #10 |
Excelsior, You Fathead.
You need to pull the cab and Radiator support inorder to change the body mounts.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
06-24-2005, 08:25 AM | #11 |
What body mount kit did you use?
Rob
06-24-2005, 09:50 AM | #12 |
thinking of pulling the body off??? start thinkin in years not weeks !!!!
06-24-2005, 10:43 AM | #13 |
Cowboy Fan for Life!!!!!!
I'm with cdowns for once here. If you're thinking about going through all the work of pulling the body off of a burb, you had better take the time to detail it out nice, which can't be done in two weeks. If you pull the body off, you had better be ready to have it off the road for at least 2-6 months at the least (and thats with a concentrated effort). ...........Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
