Just Don't Stop!
![]() Join Date: Feb 2004
Classic Auto Air (AC) is in! Review...
After talking with Vintage, Old Air, and Classic Auto Air I decided to go with the CAA kit for several reasons. They use a case that can be dis-assembled if service is required. They allowed me to use the variable compressor the LS1 motor is equipped with and retain the full warrenty on the CAA unit. They have a very attractive billet head unit for a mere $100 upgrade. Overall the install was a 3-8 hour job excluding my senario where I was integrating and building lines to use MY compressor (LS1).
Because of the tight fit inside the frame rails I had to change the location of the exit on the manifold for the liquid line. I basically TIG welded the old exit hole shut and then tapped and TIG welded the tube exiting perpendicular to the old location. To make the billet head unit fit I had to cut an aluminum plate to hold the unit in the stock location and it looks great. My cab was not a factory air cab so I had to cut the hole for the center vent which they supplied a drawing and it went in like butter. I had origionally ordered the factory reproduction vents (another $99 upgrade) for the side vents but have decided to send them back and go with billet vents. I expect to have those installed next week. Overall, it is a high quality kit and blows alot of volume from the Spal blower motor and it's VERY COLD. I still haven't measure the vent temps but I would guess they are in the 30-40 degree range. The entire kit is well designed and the only down side is the price tag. I will take some better picture in the day sometime.
1968 C10 build in process TT LSA/6L90e/9" Last edited by FirstGen; 06-23-2005 at 10:41 PM. |
![]() Join Date: Apr 2005
What was cost? Do the sell the factory control panel? Can you take pictures of the modification you made to the compressor? I'm going to install the same engine/tranny combo in a 69 burb, will I have to make this modification also? Did you use the ECE motormounts?
Thanks, Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#3 | |
Just Don't Stop!
I made my own motor mounts. Cost is $1095 which is standard for all the avilable kits (Vintage, Old Air, CAA). Then add $100 for the upgraded control and $99 for the factory vents. You will get $150 back if you are using your own compressor and brackets. I'll take some more pics later. Unfortunatly, since it is already assembled I'm not sure how much the pics will help you. Just remember to check for clearance when you drop the motor in. Most likly you will have to drop the motor in first then get the compressor in after the motor is on the mounts since it is nestled between the upper and lower frame channels. Then depending on how much you are willing to hack the frame, you will need to reweld the manifold for the liquid hose to re route the line. It will be clear when you actually get to that point in your install.
1968 C10 build in process TT LSA/6L90e/9" |
#4 | |
Just Don't Stop!
I forgot to add that they do have the kit designed to use the factory heater control to regulate everything. You can by a different harness to use a factory air head unit but it costs extra. Neither head unit is included in the price tag of $1095.
I wanna see pics of the rest of the truck! looks like a nice ride.
you got a thread with pics somewhere? |
#6 | |
Just Don't Stop!
Here are a couple...
1968 C10 build in process TT LSA/6L90e/9" Last edited by FirstGen; 06-24-2005 at 12:35 AM. |
That looks great! After living in the rank heat and humidity we've had here lately, I think I'll likely add air to my truck, and this kit looks like a winner.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
very nice! thanks!
![]() (was that the equivilent of yelling "show us your t**s!) |
Very nice. I like the look of the billet control panel installed in the truck. On the 6.0 is the compressor on the drivers side or passenger? On the F-body it's on the passenger side low and ends up between the frame rails like you stated so it's sounds similar. Thanks for the update and be sure to post a picture when you get the vents installed.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
The Classic Auto Air kit is by far the best kit out there for the money, it blows colder air at a lower fan speed than any other kit.
Rest in Peace Ed. Thanks for all the good times. |
#11 | |
Just Don't Stop!
Ed, Just wanted to say thanks again for the reccomendation. CAA proved to be every bit as good as you had described.
#12 | |
Just Don't Stop!
Brian, Yes in fact I remember now that when I had an F-body compressor and bracket it mounts using the same holes but just uses a different offset for the belt. The f-body compressor is also slightly more bulky which surprised me. To answer your question, they do mount in the same place, lower passenger side.
Just Don't Stop!
maybe these will help you visualize what I did to re-route the liquid line. If you look at the very bottom picture it is the most clear I think. The line coming straight up - both lines exit the manifold like this from GM, however if you look at the line to the left of it - that is the liquid line and it is exiting out the side of the manifold (you can't actually see the manifold just see where it is coming from).
Not sure if that makes sense???
1968 C10 build in process TT LSA/6L90e/9" Last edited by FirstGen; 06-27-2005 at 02:23 PM. |
Just Don't Stop!
Vents are in. Pics are not very clear but these are very nice looking and made out of billet aluminum.
Sure do help alot with cooling.
#15 |
FG,
Looks good! I will probably do that next spring in my suburban. I just bought a 70 suburban in Alvarado, do you think you might have time to take a look at it and snap some pictures of it. An older guy owns it and is not to computer savy. Let me know and I will call him and set it up. Rob
#16 |
Nice looking install on the motor and a/c. Did you slide your motor back when you put it in or keep it in the same spot. I installed a 93 vett LT1 in my 71 and slid it back 2" for a little more room between the front of the motor and radiator. I plan on adding a super charger so wanted more room for the added pully. What kind of milage do you get out of your set up? What tranny and gears did you go with? I had a 7r4 built for mine and dropped in 3.43's in the rear. I am hopping for about 20mpg when cruising.
Kevin |
#17 |
Re: Classic Auto Air (AC) is in! Review...
This will be my next mod after the 6.0 conversion.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
#18 |
A guy with a truck
Back from the dead... FirstGen's truck is since wrecked and I believe he has moved on to other projects. Too bad, it was a very clean truck that hauled major a$$.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#19 | |||
Union Electrician
Yeah, some soccer mom kit the truck really hard in the rear pushing the bed insto the cab. Really had to suck for him.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#20 |
That truck was bad to the bone! Here's to hoping in revives it or something similar.
Rob
#21 |
A guy with a truck
LS1 swap Porsche, from what I've seen...
He bought it as a 'beater' to get around in while the truck is getting fixed. Must be terrible...
#22 |
Where's my beer?
Man that really sucks, that was one of my favorite trucks on the board.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#23 |
HEY, nice lookin truck and nice job on the ac
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#24 |
Just Don't Stop!
Yeah guys, it's long gone. It was totaled and insurance wanted too much to buy it back. I'll be building another one soon. Here is the current project:
http://home.comcast.net/~taylortsims/hybrid.html
#25 |
Back in the sticks
Dang, that sucks! After all that work, you couldn't get it back. I'd have to cry
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
