![]() Join Date: Jul 2002
Whats this?
This piece on my blazer is toast....what is it, and are they available? Thanks......
Patch |
Member since 2000
What part?
The inner rocker, the rocker box rears side plate, the floor, or the wall that the rear of the floor pans connect too? There is like 4 different things in that one picture. ![]() or the missing bed panel? Last edited by Alexis; 06-24-2005 at 01:59 AM. |
JB-80 "Twice as Good"
....you can get new tires!!
HEY NOW! |
You cracked me up donkey69, thanks I needed that!!!!!!!
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Okay Jokers
I should of known better with you guys... The darn thing in the middle....some sort of support or something? The back end of the rocker attaches to it, and if you reach up through the wheel well you can touch it...(it has a drain plug in the back side of it.)
Patch |
If your asking about the verticle part that the bed floor sits on, I've never seen one reproduced.
Best bet is to find someone parting out a blazer/jimmy and get them to cut it off for you. Or get creative with metal working and build/replace the part. ![]() It'll be covered up by the quarter and rocker anyway. Good luck. |
![]() Join Date: Jun 2002
If it is this piece you'll have to fix it yourself, mine are bad too...
http://67-72chevytrucks.com/vboard/s....php3?t=138437 Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 06-24-2005 at 02:19 PM. Reason: forgot link... |
This is my problem
The first one is the outside...then the inside.....so these aren't available? Hmmmmm......
Patch |
Clarification
I am talking about the panel with the plug in it.....not the quarter panel.....just taking away that opportunity for wise guys part two......
Patch |
Anyone?
Anyone at all??????
Patch |
You should be able to buy the patch panel for the outside panel but you still will need the inner suport.
I can check, I think the quarter I just replaced still has a good one. |
