Old 06-24-2005, 11:26 AM   #1
motocrosschump
Removing distributor
I tried replacing the push rod gaskets without taking out the distributor, It made the oil leak worse. anyway I can't get the gasket lined up without taking out the distributor is there any special that I need to know while taking it out. I have never pulled out a distibutor before.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 06-24-2005, 11:55 AM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
What are push rod gaskets? That's a new one on me.
As far as removing the distributor goes, here's what I do:
* Remove the coil wire
* Pull #1 spark plug
* Put a finger over the spark plug hole
* Have someone keep bumping the ignition until you feel the compression push your finger (kinda' makes a farting noise)
* Right at that point turn the engine over by hand until the timing mark on the harmonic balancer lines up with "0" on the timing marker. You now have #1 piston at top dead center
* Pull the distributor cap
* Make 3 marks with a felt tip pin; one on the distributor housing where the rotor is pointing (should be to #1 cylinder). Make a mark on the base of the distributor and the block (this allows you to put it back in accurately). As you pull the distributor straight up the rotor will turn. When the rotor stops turning make another mark on the distributor housing where the rotor is pointing (this allows you to position the rotor easily so it lines up with the oil pump.
When you put it back in reverse lining up the marks and presto, the original timing is saved.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-24-2005, 12:02 PM   #3
Mongo
YES_____NO
Mongo's Avatar
Push rod gasket
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 06-24-2005, 12:03 PM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Looks like an extra small.....
Just Passin' Thru
Old 06-24-2005, 12:12 PM   #5
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 06-24-2005, 03:22 PM   #6
67chevemall
67chevemall's Avatar
Originally Posted by Mongo
Push rod gasket
now thats funny!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-24-2005, 12:49 PM   #7
70 shorty
Where's my beer?
70 shorty's Avatar
He's talking about on an inline, however that was pretty damn funny.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 06-24-2005, 01:43 PM   #8
chevymaz
What are you looking at?
chevymaz's Avatar
I recently changed my intake and had to pull the distributor. I just marked exactly where the rotor was pointing and how the cap was. I then loosened the hold down bolt, moved back the hold down bracket and pulled the distributor straight out. I set it out of the way without turning anything. On reinstall I put it right back in and after everything else was done it fired right up....maybe I was just lucky
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
chevymaz is offline   Reply With Quote
Old 06-24-2005, 02:24 PM   #9
motocrosschump
thanks
