Old 06-24-2005, 04:29 PM   #1
Russell
Professional Grade
Russell's Avatar
How does the door handle come off on these things?
Hey guys!
I've got the door handle unbolted, but I cannot figure out how the rod is suppost to come off the handle.
I am busy prepping the truck for primer, as I cannot put the interior back together until I have the roof primed...
Anyone have any idea? lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-24-2005, 05:23 PM   #2
Jonboy
Slots go on anything!
There is a clip that is a royal PITA that holds teh rod from the handle to the door lock mechanism. Once you get it free and the door handle bolts are both out, push the button in and jiggle the handle out. It is impossible to get the rod loose from the handle, the clip will need to come free at the lock. I find it easier to pull the lock loose to get at the clip. FWIW, the second one seems a whole lot easier.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 06-28-2005, 02:59 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The clip has a locking tab on the end. If you place a small flathead screwdriver blade under the tip and push it down with another one you can pull the rod out.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-28-2005, 05:51 PM   #4
SanitysBane
I have just the tool you need Russell.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-28-2005, 08:09 PM   #5
Russell
Professional Grade
Russell's Avatar
haha, I was actually using that tool on the truck tonight! I showed those rivets who is boss!
Old 06-30-2005, 09:54 AM   #6
mhicks
mhicks's Avatar
Wait till you try to put it back on.........
mhicks is offline   Reply With Quote
Old 06-30-2005, 01:04 PM   #7
Russell
Professional Grade
Russell's Avatar
Which is why I decided I shall do some fancy masking tape work
Old 06-30-2005, 02:26 PM   #8
CHEVYE
my gas saver
CHEVYE's Avatar
question
is there an easy way to loosen the handle up so you can tape around it easier? i will be geting close to doing this soon.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
