06-28-2005, 07:09 PM | #1 |
Next item on my wish list, may need help locating
Tailpipe for the exhaust, I'm looking for the factory style which splits into two pipes shortly after the muffler. Any Idea who sells these? Everywhere I try its just the (IMO) crappy looking single large pipe.
06-28-2005, 08:09 PM | #2 |
Professional Grade
Maybe grab an exhaust setup for a newer TBI 350 truck? They were single into duals. 305 was a single pipe
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-28-2005, 11:06 PM | #3 |
Oem Mufflers
It looks like you could find that oem look at your local muffler shop, or I'm pretty sure they could weld up a custom setup that your looking for.
06-28-2005, 11:12 PM | #4 |
u want the y pipe for the frnt or the rear setup out of muffler on my truck i got true duals from exhaust back to 2 flows and dumps
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
06-28-2005, 11:41 PM | #5 |
Bodydropped if you remember that some of our trucks in the early to mid 80's had mufflers with dual tailpipes that exited behind the left rear tire of the truck. I believe he's looking for that type of setup to reinstall on his truck insted of the typical muffler with one single tailpipe exiting behind the rear tire.
06-29-2005, 01:17 PM | #6 | |
06-29-2005, 12:25 PM | #7 |
they sell them that r single inlet dual outlet in many brands all u really need is the muffler and let the shop make it from the outlet to the rear of the tire
06-29-2005, 02:29 PM | #8 |
i recently cut a flowmaster 50 series off a burb which had single 3 inch inlet and dual 2 1/2 outlets and there were side bye side behind the left rear wheel
heres a pic of the muffler im talkin about
06-29-2005, 04:43 PM | #9 |
I bought what you are talking about through JEG's.
It was a muffler and tailpipes - single in, dual out. If I remember right, it was around $130 and was aluminized, mandrel bent pipes. It didn't go together as smooth as some of the other kits I've bought, but it did go on. Edit: it was a Dynomax kit - I think 289-17467 it says here $135.99 but this catalog is a few years old.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 06-29-2005 at 04:49 PM. |
06-29-2005, 07:06 PM | #10 |
Gibson exhaust also has some cool mufflers with dual exits that you could look into and price.
