Old 06-28-2005, 09:43 PM   #1
jamal
jamal's Avatar
tranny help
Me and my father-in-law placed a built 350 and a rebuilt turbo 350 in his 72. I'll have to post pics it is an awesome truck. The tranny shop is reliable, and I had a master overhaul kit with a shift kit installed. We thought the old tranny was bad b/c we couldn't get it to shift. When we put this one in it won't shift either. However, both will shift through all gears if I shift manually from 1st-2nd-3rd. All three gears work great and it shifts fast and hard like it is supposed to. He replaced mod valve, replaced rubber vacuum hose with copper, and nothing works. How much vacuum does this require? It is not a real strong vacuum due to being plugged in to a small nipple on the carb. The next step is putting the line on a bigger nipple to get more vacuum. Any ideas? I am racking my brain here. I don't know a whole lot about auto trannys.
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 06-28-2005, 09:59 PM   #2
krue
Designated A-hole!
krue's Avatar
Mine is plugged into a fitting in the manifold between the carb and dizzy. Probably not getting enough vacuum from the carb (ported vacuum fitting maybe?).
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-28-2005, 10:28 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It will either be the wrong vac fitting, or a bum vac modulator. Did you by chance take the modulator off the old tranny and install it on the new one?
Old 06-29-2005, 12:07 AM   #4
jamal
jamal's Avatar
no bought a new mod valve for 10.99 at autozone
Old 06-29-2005, 01:37 PM   #5
jamal
jamal's Avatar
anybody else know anything I could try?
Old 06-29-2005, 08:38 PM   #6
krue
Designated A-hole!
krue's Avatar
You can try putting a vacuum gage on your line and see how much vacuum your getting. Did you switch the fitting it was connected to?
www.daveramsey.com
Old 06-29-2005, 08:56 PM   #7
jamal
jamal's Avatar
It was same one the old tranny was connected to, however the old tranny didn't shift right either. I am sure the fitting has a little less vacuum due to the bigger cam, and am going to try the intake fitting next.
Old 07-03-2005, 08:44 PM   #8
jamal
jamal's Avatar
Ok now I have great vacuum going to new mod valve, and still does not shift on its own. Any other ideas? What else would make it not shift? It shifts great manualy just not on its own
Old 07-04-2005, 08:27 AM   #9
jamal
jamal's Avatar
anybody?
Old 07-04-2005, 10:20 AM   #10
Hart_Rod
Hart_Rod's Avatar
Just a shot, was the tranny built with a manual valve body -- one that requires shifting into each gear. I know they do this in race cars. Could also be somethig with the rebuild. Have you talked to the tranny shop yet?
Rob
Hart_Rod is offline   Reply With Quote
Old 07-04-2005, 04:49 PM   #11
Stiffler
Stiffler's Avatar
1972. Does the TH350 have a kickdown-cable from the tranny to the carb? While this may not root of your problems, it something that should be in adjustment.
You wrote that you installed a new vacuum modulator. Is is the "adjustable" type? Pull the line of the Vac.Mod and see if there is a slotted set screw that could be adjusted. If so, get a small tip (slot) screwdriver and adjust accordingly. I don't recall if turning inward lengthens or shortens the shift point. Best of luck.
Stiffler is offline   Reply With Quote
Old 07-04-2005, 05:07 PM   #12
Longhorn Man
stiffler has a good point, many (even stock replacements) are adjustable. Turing it in will raise the shift point, unscrewing it will lower it.
The only way the kickdown cable would do this is if it is pulled out and stuck in that position.
Old 07-05-2005, 05:38 AM   #13
GMC AMI
GMC AMI's Avatar
Vac. should be hooked directly to the intake manifold and do check adj. screw.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 07-05-2005, 11:29 PM   #14
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Take the kickdown cable loose at the carburetor and see if the inner cable slides back into the outer housing. If it does then try driving it and see if it will shift.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-06-2005, 08:56 AM   #15
jamal
jamal's Avatar
Have done all of that, replaced and adjusted mod valve, and installed new kickdown cable but still does not shift. Tranny is out and going to trans shop tomorrow
Old 07-06-2005, 12:09 PM   #16
70 shorty
Where's my beer?
70 shorty's Avatar
I'm wondering if it had a manual valve body all along, even before the trans work and it still does. Maybe that's the problem as Hart Rob said.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 07-06-2005, 07:27 PM   #17
jamal
jamal's Avatar
started as a stock 350 tranny that was slipping and had it built no manual valve body, but the trans shop did say he thought it was in the valvebody...will know for sure soon and will update
