![]() Join Date: Sep 2002
How do you id the ratio on rear gears?
Now I know this one has probably been on here 100 times, but I'm considering buying a posi rear with 3:73 ring and pinion gears. Can someone tell me what numbers and/or tooth count which would identify the correct ratio? Also, anything to look out for in the posi (pics only)?
Any info or suggestions are very much appreciated. Thanks. Scott |
Questionable
It's been asked enough that I know the answer
![]() Put a mark on the driveshaft. Lift one rear tire and release the e-brake. Count how many times you gotta spin the tire for the mark on the driveshaft to make one full rotation. Thta equals (approximately) your gear ratio. Example: If it takes 3¾ tire spins to make the driveshaft travel around once, you have 3.73 gears or close to it. 3 times would be 3.07 or whatever. 4 would be 4.11 or whatever. I don't know the exact numbers, I'm taking those off my head from reading previous other posts.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#3 | |
jackup BOTH wheels rotate the DRIVESHAFT 33/4 turns of the DRIVESHAFT makes the wheel turn 1revolution is 3:73gears
#4 | |
Questionable
#5 | |
Keep On Truckin'
Divide the ring gear tooth count by the pinion gear tooth count to get the ratio. I don't recall the tooth count for 3:73's but the math above will tell you what you got..
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
![]() ![]() Join Date: Jan 2005
I believe the ring has 41 teeth and the pinion has 11 on a 3.73. The ring gear should have 41:11 stamped on the outer diameter.
#7 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
Saving 1 truck at a time!
pjmoreland had it right 41/11 for a 3.73...at least that is what I counted on mine!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Thanks guys. The info Pjmoreland provided was what I was looking for, as the components will be removed from the housing (should have mentioned that previously).
Thanks again for everyones input. |
