Old 06-29-2005, 11:22 PM   #1
shifty
Questionable
shifty's Avatar
idiot light -> gauges dash swap ??
Note: I already read the FAQ post about how to do this conversion. I read the page it was linked to and got the idea: I need to swap some wires around.
Has anyone documented this process or have a link to someone who has? I will take lots of pictures when I do it for sure and post a FAQ thread, so .... the more help I can get the better it is for anyone else looking to do this swap.
- Do I need any special parts?
- Will I need to touch the fusebox?
- Should I buy a new wiring harness for the engine bay?
- Do I need to buy a new water temp sending unit?
- Oil sending unit?
- How did the stock oil pressure sending unit work and how was it wired?
Thanks!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-29-2005, 11:29 PM   #2
matt67350
matt67350's Avatar
Check GMCPauls web page. I think there is a wiring chart that tells you were to move the wires.
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 06-29-2005, 11:46 PM   #3
longhorn71
longhorn71's Avatar
I used the info found there and it works great!!
longhorn71 is offline   Reply With Quote
Old 06-30-2005, 12:08 AM   #4
shifty
Questionable
shifty's Avatar
Thanks, I got the information on where to move the wires from the FAQ page (it links to a site with this info, maybe it's GMCPauls, I forgot already).
I'm wondering about the other questions I asked and whether anyone has pics of the process.
Old 06-30-2005, 08:32 AM   #5
67chevemall
67chevemall's Avatar
GMC pauls write up is what I just used. I even found the 67 steel oil pressure line.
And a vaccum gauge from old Harold. I cut up the glass and put a AM tach in the middle. Bought a wood bezel of ebay and cut out the middle to fit around the wider
camaro column. Was alot of slow custom work and Alot of beer.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-30-2005, 08:58 AM   #6
70c10
67-72 Addict!
70c10's Avatar
I'll be watching this post because I couldn't figure out GMCPauls directions.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-30-2005, 11:44 AM   #7
shifty
Questionable
shifty's Avatar
Glad I'm not the only one . I'm a visual person. It really helps to see pictures and ask questions for everything that people forget to tell you or don't explicitly say.
Old 06-30-2005, 07:44 PM   #8
avejoe
Custer had a plan too.
avejoe's Avatar
Re-wiring the loom is pretty easy once you figure out how to remove the wires with the metal connector intact. Once the individual wires are out (do this one at a time), you can just plug them into the loom in the correct spot.
I used a small allen key to depress the "catch" on the metal connector to release the wire.
I did the swap without any problems in one shot. This means it has to be easy.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 07-01-2005, 08:04 AM   #9
67chevemall
Yes and when your done rewiring you'll have two wires left over to use for the new
Batt. gauge.
