06-30-2005, 01:21 AM | #1 |
Rally wheels?
There seem to be at least two different rally wheels. The small slotted ones and the larger slotted ones. Are the larger slots for a car/el camino and the small slots for a pickup? What would be an average price for a set of each with the rings and center caps? What is the lug spacing on each of these wheels? Thanks in advance.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-30-2005, 05:33 AM | #2 |
its all about the +6 inches
the rallys you are talking about only came on trucks and police cars, and that's all they'll fit.
Although, I don't have the answer for the why/when/where on the big hole verses little hole. |
06-30-2005, 10:25 AM | #3 |
I got my used set for $250. Sandblasted and re-painted with new trim.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
06-30-2005, 10:36 AM | #4 |
Looks good at 20-ft .....
I paid $ 150 for set of five 8"-ers w/ center caps, & $ 25 more from another guy for wrong (narrow) trim rings, but they'll do 'til I can find better rings. Actually the narrow rings don't look all that bad on the deep rims. Rotary wire brush on a drill, a good de-greasing, & rattle can paint on the rims seems to be holding up well out in the weather for a year. Maybe sandblast & do it better later.
Had to grit my teeth when I saw a nicer set of 4 rims, caps & rings at a show/swap recently that went begging, offerred for only $ 75.00. Shoulda bought them, I know. |
06-30-2005, 02:53 PM | #5 |
Just to clarify are you talking about 5 or 6 lug ralleys? 6 lugs have larger slots aroung the edges and 5 lugs have smaller and more slots. 6 lugs fit 67 to 70 1/2 2wd and all 67 - 72 1/2 ton 4wd's, where the 5 lug ralleys with the smaller slots only fit 71-72 2wd 1/2 tons........
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
06-30-2005, 08:21 PM | #6 | |
Ooops...that would be 5 lug. Here are some of the different wheels I was referring to. Corvette/Camaro/El Camino, 4x4 truck, 2wd truck, and different widths. Thanks. Tim
large slots 15/?"/5 http://cgi.ebay.com/ebaymotors/ws/eB...558843294&rd=1 thin slots 15/6.5"/5 http://cgi.ebay.com/ebaymotors/ws/eB...983000097&rd=1 thin slots 16/8"/6 http://cgi.ebay.com/ebaymotors/ws/eB...983759846&rd=1 thin slot 15/8"/6 4x4 http://cgi.ebay.com/ebaymotors/ws/eB...983891423&rd=1 thin slots 15/9"/6 http://cgi.ebay.com/ebaymotors/ws/eB...983759846&rd=1 silver argent paint http://cgi.ebay.com/ebaymotors/ws/eB...559199010&rd=1 -------------------------------------------------------------------- Quote:
06-30-2005, 09:32 PM | #7 | |
Here goes . . ....
PIC/Ebay listing #1: Car Ralleys or commonly refered to as 'corvette ralleys'. They came in factory sizes of 14x7, 15x6 ~ 8 & are available in many other sizes through the aftermarket. Originally just for GM 5x4.75" bolt patterns, the aftermarket variety come in many more bolt patterns including 6-lug for older chevy trucks. PIC/Ebay listing #2: 15" 'Van' ralleys. These are a 'skinnier' version of the factory 'truck' ralley that came on vans as well as taxis & cop cars/caprices. They were 15x6.5" & are the same 'appearance wise' as the wider 15x7 ~ 8" truck ralleys. Factory 5x5 bolt pattern. Work great when combined w/the wider 8" truck ralleys for a budget 'big & little' look of streetrods/hotrods. PIC/Ebay listing #3 & 5: Late model (90's anyway) 16" 6-lug truck ralley. 6x5.5" bolt pattern w/lots of offset (almost like a front wheel drive). They came mainly on HD 1/2 ton & 4x4 trucks. PIC/Ebay listing #4: 15" 6-lug 'truck' ralley from a mid 70's ~ 80's 4x4 or Blazer. 15x8" & a good offest for 62~70 trucks. Older van or truck ralleys (5 & 6-lug) had center caps that mounted w/3-bolts/screws. Some had caps that attached via screws from the front, & some attached from the backside of the wheel. Later model center caps (again 88-up model) can be used w/their corresponding 'conversion' lugnuts & lugnut caps or . . .... they can attach like the earlier style center caps w/screws from the backside & use standard chrome lugnuts.
06-30-2005, 10:25 PM | #8 |
stockton wheels makes good ones, check them out.
06-30-2005, 10:45 PM | #9 | |
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
07-02-2005, 09:52 PM | #10 | |
07-03-2005, 01:02 AM | #11 | |
I cant get the link to come up for them but go to Summitt web page and type in what you want. I bought the corvette style Ralley wheel. The 15X10 are $62 and the 15X8 are $58
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step Last edited by 70short/step; 07-03-2005 at 01:10 AM. |
07-03-2005, 03:01 AM | #12 | |
