Brake Booster Help
I just got a brake booster off a board member and Ive got a pretty good handle on how to install it. But I had one question: where does the vacume hook up? I have a stock 307 that originally had manual brakes.
thanks!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
It should hook up to FULL Manifold vacuum, either a port on the manifold itself or to a port on the base of the carb.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
There is a plug in the top of the manifold behind the carb - would this be a full vacuum?
Yes, just take the plug out and get a fitting to put in there to allow you hook the vacuum hose up to. Make sure you use some form of thread sealer whether thread tape or the liquid type.
