Old 07-01-2005, 06:53 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Question Planning tranny swap....
I will be dropping in a 406 in my truck in the near future. My current tranny is the original powerglide that is tired and simply boring. My problem is I can't decide between a th350 or the th400. The engine puts out upwards of 470hp and 520 ft.lbs so I want something that can handle what i put to it. Does anyone run this kind of power and if you do, what is your setup???
910
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 07-01-2005, 07:25 PM   #2
69 longhorn
IMO, there is only 1 auto trans to run in the hypo app.....that would be the bad @ss 400 turbo hydro! it will take 18-20 more ponies @ the rear wheels to run, buit a good stock rebuild, + shift kit & converter to match your cam...should handle all the power/tork you are looking to give it L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 07-01-2005, 08:39 PM   #3
69 Short Fleet
Are you for sure going with an automatic? I have a granny 4 speed in mine and would like to upgrade to a T-56 (6 speed) later on, its a bit of work to get one in but ... just a thought, Doug
69 Short Fleet is offline   Reply With Quote
Old 07-01-2005, 10:19 PM   #4
69GMC910
MOTORHEAD!
69GMC910's Avatar
The last thing I want is to blow up a tranny, would a th350 need a fair amount of cash dumped into it to handle the power?? Also, what are your opinions on 700r4's? Is the lock-up converter an issue? Is it as strong as the th400? How many RWHP does it require to run???? Fill me in!!
910
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 07-02-2005, 12:14 AM   #5
QKENUF4U
QKENUF4U's Avatar
TH-400 all the way
QKENUF4U is offline   Reply With Quote
Old 07-02-2005, 05:27 AM   #6
GMC AMI
GMC AMI's Avatar
400's are stronger, a good 350 turbo handled my 455 Stage 1 Buick built with cam, highrise and roller rockers thru 2 years of drag racing and street driving with 0 problems!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 07-02-2005, 07:41 AM   #7
Huck
Huck's Avatar
A good Turbo 350 is stronger then most 700R4's and a Turbo 400 is about the best heavy duty auto you can get. It does not have an overdrive but that is about it's only shortcoming.
Huck is offline   Reply With Quote
Old 07-02-2005, 08:17 AM   #8
cdowns
cdowns's Avatar
you should go for a performance rebuild weather you decide on a 3speed or a 4speed overdive is just a matter of budget and how you intend to use the truck. a good place for bullitproof performance trannies is www.fbperformance.com
Old 07-02-2005, 08:52 AM   #9
dennislbrooks
dennislbrooks's Avatar
options
I would take a good look at a 700R4 like a B&M. If you plan to cruise at all the overdrive has better economy, will place less wear and tear, and does not suck down 20 ponies and weigh more like a 400 turbo. A good 350 heavy duty built should be considered. I run a GV overdrive ( uses 1 hp) behind my 350 turbo --however, I run a small block.
Call some of the professionals.
dennislbrooks is offline   Reply With Quote
Old 07-02-2005, 08:25 PM   #10
Long Roof
Old School, New Style
Long Roof's Avatar
4l80e is an overdrive 400 basicly. They are a little hard to come by though. I would go with a good 400 and then take a look at Gear Venders over drive unit.
Aaron
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
