Old 07-02-2005, 08:58 PM   #1
Matt_305
Matt_305's Avatar
Question Engine and tranny swapping questions...
My truck (81 gmc lwb 1500) currently has the 250ci straight six mated to a 3 speed auto tranny, my other truck (85 gmc lwb 1500) has a 305V8 mated to an SM465.
1)Are the drive shafts the same length or compatible? (305 has 2 piece 250 1 piece)
2)Is the clutch pedal mechanism and clutch fluid resevoir etc hard to hook up?
3)Is the shifter hard to line up through the floor?
4)Any other difficulties I should know about?
5) Are hoses and wiring etc. hard to figure out and make compatible?
The front ends of both trucks are already torn down except the front bulkhead I guess you'd call it (what supports the rad). Thank you for your help sorry to ask so many questions but I'm a bit of a newbie at the whole thing but have come this far and feel hey why not go all the way. Thanks again.
Matt
1981 GMC Sierra 1500 4.1L I6
1985 GMC Sierra 1500 5.0L V8 (Parts Truck)
Matt_305 is offline   Reply With Quote
Old 07-04-2005, 05:44 PM   #2
Matt_305
Matt_305's Avatar
bump
Old 07-04-2005, 06:02 PM   #3
1FaastC10
1FaastC10's Avatar
shoudl be a direct bolt in, save for the clutch master cylinder mounting holes, and the shifter hole. i know there are dimples in the firewall to show you where to mount the master cylinder, my 86 had them, as did my buddy's 84. since you have both trucks, you can take measurements from one and transfer the parts to the other truck. should be a very painless swap.
1FaastC10 is offline   Reply With Quote
Old 07-05-2005, 05:07 AM   #4
the baron
the baron's Avatar
Hi Matt ,
what are your intentions precisely ?
do you want to put the 305 on the auto tranny ?
an engine swap from a truck to another is easier than swapping the whole transmission , fitting pedals , boring holes to allow the fitting of the poke , etc...
greetzzzz
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 07-05-2005, 07:53 PM   #5
Matt_305
Matt_305's Avatar
My intentions are to change the engines and transmissions so yes putting in the standard still on the 305,I must do everything the hard way, still wondering are the driveshafts compatible? could the standard go to the single piece?
Old 07-05-2005, 09:24 PM   #6
1FaastC10
1FaastC10's Avatar
check the part numbers on both trucks for the rear u joint. i'd almost bet they're the same. the driveshafts should be fine if both trucks are the same wheelbase, just keep the driveshaft with the trans it was originally mated to.
Old 07-06-2005, 06:36 PM   #7
Matt_305
Matt_305's Avatar
Hey thanks for the help guys, sounds good, don't think I'll get too lost.
Old 07-07-2005, 08:02 PM   #8
Matt_305
Matt_305's Avatar
I guess I've changed my plans due to time contrants from work I will only be switching motors for now and perhaps transmissions later. Is there any added complications from doing this I should know about it looks pretty straight forward, thanks again
Matt
Old 07-08-2005, 02:09 PM   #9
Matt_305
Matt_305's Avatar
bump
