Old 07-03-2005, 07:05 PM   #1
JerseyGirl
American Woman!
JerseyGirl's Avatar
Need help with disc brake set up...
I tried looking thru ALL the threads for this & I couldn't find what I needed. I guess if I really searched High & Low..I would have found it..
Are the axles & length & number of splines the same from the 5 lug to 6 lug on the 12 bolt rear?
I am thinking about converting over my 6 lug to 5 lug, I know pretty much all what needs to be done, but needed to ask the above question...has anyone done it & if so, can ya put a link showing what ya did?
Any help would be sooooo much appreciated!
Tree
Tree Was Here!
Click here to see pics of my new rig!
JerseyGirl is offline   Reply With Quote
Old 07-03-2005, 07:56 PM   #2
hilljob26
hilljob26's Avatar
i converted a 70 w/6 lug to a 72 5 lug a couple of yeras ago,and it worked out just right,i dont think you can swap out a 6 lug 4x4 rear w/ 5 lug,but i am pretty sure you can do a 2wd
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 07-03-2005, 08:01 PM   #3
JerseyGirl
American Woman!
JerseyGirl's Avatar
Yea they are both 2wd..I appreciate the response!
Tree Was Here!
Old 07-03-2005, 08:11 PM   #4
neonlarry
neonlarry's Avatar
Depends on which width rear you have (on your truck). There was a mid year switch to a wider rear, if you have the wider one the 5 lug will go right in. The narrower one will need spacers. The other possibilities are an after market 5 lug axle or have yours filled and redrilled.
Check out this page for measurements:
http://50chevy.freeservers.com/Suspension_Widths.html
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-03-2005, 08:14 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Spacers is not a good idea, the portion of the axle shaft that rides on the bearing is hardened...but the rest of the axle shaft isn't. I kn ow it's been done and stuff, but that's a lot of damage if an axle gives out...esp on the freeway.
Old 07-03-2005, 10:50 PM   #6
JerseyGirl
American Woman!
JerseyGirl's Avatar
The donor I am using (or will use) will be coming off a '69.
All I want to do is put disc brakes on the front...I have power drums brakes now on my '70...but would LOVE the disc up front.
Is there any 6 lug trucks that have power brakes that everything will just tranfer onto my truck without any problems?
Tree Was Here!
Old 07-04-2005, 04:56 AM   #7
GMCPaul
1970 6lug rear axles are the same length as 1971 & 72 5lug rear axles so axles and drum brake drums can be swapped, 1969 and earlier rear axles are shorter by approx. 3/4" each and if you try to swap late model 71-72 axles into them they protrude a additional 3/4" further out so you can not do a direct swap on axles and drums only. Spline count on all 1967-72 1/2 ton 12 bolt rearends is the same.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 07-04-2005, 05:03 AM   #8
GMCPaul
You stated the donor truck is a 1969, in 1969 they had 6 lug front & rear and drum brakes front and rear so if your getting a 69 with disc brakes in front & 5 lug front & rear someone has then converted it to disc brakes & 5 lug. If thats the case you need to find out what year group parts were used to convert it.
GMCPaul
Old 07-04-2005, 09:42 AM   #9
JerseyGirl
American Woman!
JerseyGirl's Avatar
GMCPaul
That is what my husband figured! I appreciate your help, the truck had a new master cylinder & booster as well...don't know if it's worth going thru all the trouble to convert it over. Thinking about just putting the front spindles & disc brake assembly on & finding a 5-6 lug adapter for the fronts & keeping my wheels & tires...any suggestions would be appreciated!
Tree Was Here!
Old 07-04-2005, 09:54 AM   #10
GMCPaul
The donor truck your speaking of if it has truck 5on5" bolt pattern with 1 1/4" thick rotors then you can use the standard 6 lug rotors ourselves and most other parts vendors carry to replace the current 5lug rotors on it to keep your 6 on 5.5" bolt pattern you currently have.
If you like the wheels better on the 69 and its got a 71-72 rearend under it then you can pull itsd rear axles and drums and swap with your 1970 axles. If its got a 73 up rear end the axle shafts are wrong length for the swap.
GMCPaul
Old 07-04-2005, 10:03 AM   #11
boraxman
Keepin an eye out
boraxman's Avatar
Hang on JerseyGirl, im on my way to help
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 07-04-2005, 10:47 AM   #12
hilljob26
hilljob26's Avatar
they do make a 6 lug rotor for the front of that,try like manestruckparts.com they have the rotors for 100 bucks each i think,which isn't bad if you are really stuck on the 6 lug
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 07-04-2005, 12:47 PM   #13
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The new 6-lug rotors onto a 5-lug spindle is a "bolt on".
I am sure Manestruck & others may have these, but I would recommend you contact GMC Paul first. He is on the board, giving lots of free information, has the parts in stock and I will bet his prices are better also.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 07-04-2005, 02:35 PM   #14
JerseyGirl
American Woman!
JerseyGirl's Avatar
Did NOT know that..very cool! Thanks for that info...
And thanks guys for the help. GMCPaul you are da man!!! Very helpful info..thanks soooooooooo much!
Tree Was Here!
