07-05-2005, 06:21 PM | #1 |
Any ideas for firewall hood hinges?
Does anyone know of a good quality firewall mounted hinge that would work? I need to relocate my hinges from the fenders to the firewall. I have a 71 SWB with a 2" body drop and a "Z"ed frame and in order to get it as low as I want for show I need to section the top inner edge of the fender 2". Right now my fenders lay on my tires before I am at full bump. The problem I run into is the hinge is the only thing in the way of me fixing this problem . Also I want to put stock inner fender wells back in so it is needed for this as well. Any info or pics would be great.
Kevin |
07-05-2005, 10:42 PM | #2 |
Could always go this way.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:28 PM. |
07-05-2005, 10:56 PM | #3 |
Out draggin'
Try getting ahold of Ghettocrewzer on the 67-72 Burb forum. I believe he is using firewall mounted hinges on his burb(layin on 22's...)
L8R - Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
07-06-2005, 07:19 AM | #4 |
Thanks JoE I will try getting a hold of him. Also thanks for the tilt idea but I am keeping the bone stock look from out side and don't want any extra body lines.
Kevin |
07-06-2005, 08:42 AM | #5 |
Car Knocker
I believe someone has put a front tilt hood on by using the hinges and latch off a mid 80's buick lesaber.(sp) That would move the hinges to the front of the truck.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
07-06-2005, 08:53 AM | #6 |
To save from reposting the pic's here is a link to a buick setup
http://67-72chevytrucks.com/vboard/s...6&postcount=34 I have a few more that were not posted if you need to see some close ups.
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s |
07-06-2005, 07:57 PM | #7 |
Thanks for the leads but I want mine to open the stock direction. My doors may end up opening in reverse but not the hood. Any door set up picks?
Kevin |
07-07-2005, 08:22 AM | #8 |
here ya go
