07-12-2005, 10:36 PM | #1 |
Brake line needed.
I am in need of the brake line on the rear passenger side axle. I have a 10 bolt coil rear 2wd. Where it goes into the tee it is 1/4" I believe. the other end goes into the brake drum housing. all I need is the short line. Any help would be great!!! Thanks JIM
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
07-12-2005, 11:36 PM | #2 |
If you can give me to at least the weekend I might be able too help. I will need to look and make sure the one I have is in good condition.
If you don't hear back by Saturday drop me an email. thejoker(at)gatewayriders(dot)org . |
07-12-2005, 11:40 PM | #3 |
No problem!! Thanks
07-12-2005, 11:54 PM | #4 |
I'm watching you!
If that doesn't work out you can pick up a piece at your local auto parts store pretty cheap. Just bend it by hand into shape.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
07-13-2005, 12:16 AM | #5 | |
07-13-2005, 12:24 AM | #6 |
I'm watching you!
Hmmm weird. OK just a thought. Good luck on your adventure.
Mike
07-13-2005, 07:03 AM | #7 |
Somethings weird most all drum brakes use 1/4 line, did you get a 3/16 fitting to screw into it? Are you sure the wheel cylinder has not been replaced with a newer metric cylinder by mistake? 1/4 x 3/16 adapters are available from NAPA it is the same adapter used when putting a disc brake front end on a drum brake truck. What year is your truck with a 10 bolt rear?
Rest in Peace Ed. Thanks for all the good times. Last edited by MOTHERTRUCKERS; 07-13-2005 at 07:05 AM. |
07-13-2005, 09:17 AM | #8 | |
