Power Door Locks?
Has anyone ever installed these? I found that the pickup I just purchased had an alarm system, and the previous owner has already done the work of installing the "arm" that locks and unlocks. I'd love to be able to take the two wires from this actuator and keep using the locks, without messing with the dumb alarm system (the whole thing is getting taken out.)
I read the blue and green are just lock/unlock signals being sent to the actuator. I just need to know how to finish hooking them up independently. I know LMC sells a kit for power locks, if anyone has that kit and could make a scan of the instructions, I think I'd be set! |
I need the same thing..
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
Is he leaving the relays that make them work. You need to have the relays to make them work the motors work on voltage reversal meaning one side is + and the other – in lock and the opposite in unlock. If he leaves the relays all you will need to do is figure out if the input wires needs + or – then get a switch that is a 2 way momentary and put it some where.
I would try to find just a keyless remote entry system you can get them cheep at the parts house or on eBay. If the actuators are there the hard work is done all you would really need is to hook up power to the box and then to the motors...
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
