BB Serpentine belt setup
Does anyone know if a Serpentine belt setup off of a 90,s 454 work on a 72 402BB?? Off of a SS454 or 3/4 to 1 ton 454?
bogey5 |
'Burban Legend
![]() Join Date: Apr 2005
Crucial Part
I believe that it has been posted many times on here that it WILL work. THE MOST IMPORTANT THING, is you MUST use a reverse rotation water pump because the serp set-up spins the other way ON THE PUMP. Get one for the year truck you took the serp system from. Good luck to you, Mike
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
Yes they will work according to the owners of trucks I've spoken w/@ several shows. But, like hotrodmtodd stated, you'll need a reverse rotation long waterpump.
I have a new setup on mine. There is NO clearence for a clutch type fan on this setup. You will have about 2 3/4" between the water pump pulley and the Rad. This forced me to go 16" flexilite fan and 12" electric in front of air condenser. You can't go any larger of a flex fan because it will interfear with the air-conditioner pulley. I used a 1" spacer off the water pump so it would not hit anything. If I went anymore on the spacer I would not have enough room to fit a wrench in to bolt the darn thing on. If you don't have air you could go with big electric fan infront pushing .
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
