07-14-2005, 10:21 PM | #1 |
5 speed trans swap
Right now I've got an 85 small block with a SM465, 2wd. I have an opportunity to score an 89 Cheyenne with a V6 and want to swap the 5 speed, driveshaft and rearend in to my truck. Will the 5 speed bolt up to my small block. I crawled underneath the CHeyenne and the bellhousing looks completely differnt???
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305 5 speed, 3.42 rear 2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L 1999 BMW 528i |
07-14-2005, 10:52 PM | #2 |
Professional Grade
Hmm, I think that the bellhousings should be the same. I was pretty sure that most chevy engines had the same bellhousing.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
07-15-2005, 07:49 AM | #3 |
The 5 speed transmission on the '89 chevy looks different than the setup I have on my '85 with the SM465. I am pretty familiar with my bellhousing since I swapped in the 465 a few years ago. It has a bellhousing that bolts to the back of the motor and it holds the hydraulic clutch. the 465 bolts to the back of the bellhousing with 4 large bolts.
The 5 speed on the '89 looks like the bellhousing is part of the transmission. It also has a hydraulic clutch but it isn't in the same spot as the 465 setup. I am going to get the whole truck so I will be able to grab whatever I need. I just wanted to know if the 5 speed will bolt to the back of my '85 small block. thanks.
07-15-2005, 08:48 AM | #4 |
the bellhousing on those trannys is part of the case. If it is bolted to the 4.3 it should bolt to your engine. The pads on the rearend may have to be moved along with the shock mounts.
07-15-2005, 11:18 AM | #5 |
why would he have to move his spring pads and shock mounts? what am i missing?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
07-15-2005, 02:38 PM | #6 | |
No No
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
07-15-2005, 04:23 PM | #7 |
helps to read the whole post.... i failed to see the driveshaft and rear end...
