07-15-2005, 09:19 AM | #1 |
Removing the Tranny?
I can't even loosen one of the bolts on the tranny to separate it from the engine. I have put penetrating oil on it and its still a b****. there is not enough room to get a cheater bar on it. Any ideas?
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
07-15-2005, 09:39 AM | #2 |
Use PB Blaster to lubricate the bolts...several coats might be necessary.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
07-15-2005, 10:05 AM | #3 |
Msgt USAF Ret
I usually drop the crossmember and lower the tranny and then use a couple of extensions with a breaker bar or my impact tool, be sure the distributer cap clears the firewall and the fan clears the radiator, and be sure to support the engine.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-15-2005, 10:20 AM | #4 |
i usually yank the tranny while it's attatched to the engine. Much easier to split em on a bench or on the floor
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
07-15-2005, 10:25 AM | #5 |
Questionable
Quick solution that will benefit you for years.
I had the same problem. I went out and bought one of those right-angle impact wrenches and hat to blast mine off. PB wasn't do crap. I bought a new compressor while I was at it. Total cost: $200. I could have borrowed one from a friend, but ... needed my own stuff. Didn't need anything fancy, just something to use in the garage. Someone stole my old one.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
