Old 07-17-2005, 08:18 PM   #1
mustngr
Power steering seal
I need to replace the seal on my '85 CUCV (1 1/4ton 4x4). Anyone have any advice? Can it be done with the box still in the truck?
1984 CUCV 6.2 Diesel
1983 C30 dually 6.2 Diesel
1989 Mustang mare, high miles, low maintenence
Zero Fords
mustngr is offline   Reply With Quote
Old 07-17-2005, 10:15 PM   #2
MM in NM
Which seal? There's a seal on both the pinion shaft and the steering column shaft. I've replaced the steering column shaft seal with the box still in the truck on both my 73 Suburban and my 76 K20. I'm probably going to do the same thing on the 79 I'm currently working on.
MM in NM is offline   Reply With Quote
Old 07-18-2005, 09:51 AM   #3
mhicks
mhicks's Avatar
I am also needing to do my steering box. Can it be done on the truck?(Pitman Arm)
mhicks is offline   Reply With Quote
Old 07-18-2005, 09:07 PM   #4
mustngr
It's the top seal, steering shaft.
Zero Fords
