06-23-2002, 05:45 PM | #1 |
Under dash wiring....Who makes the best harness???
Just about to put in a AC dash (after I go pick it up from alex)and I thought I might as well put in a new wiring harness while Im messing with taking the dash out.
To anyone that has put in a new harness.....Who makes the best for fit/quality?
Life is good with a 6-71 supercharged 355 in a 72 camaro |
06-23-2002, 07:14 PM | #2 |
I would probably go with M&H if I was going to replace that one section I am replacing my whole thing so I went with Painless and I really like it.
06-23-2002, 07:37 PM | #3 |
Unregistered User
I got an M&H from GMCPaul, and it is great. It's exactly like the original.
71 SWB Stepside SB400/TH350 |
06-23-2002, 07:59 PM | #4 |
2 words....General Motors.
I have a Painless Kit, but its not that painless. It is nice, but not all that.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks Last edited by Low69CST; 06-23-2002 at 08:01 PM. |
06-24-2002, 12:40 AM | #5 |
I got M&H on the burb and it works fine,and they have a good tech line also.
Things happen for a reason! |
06-24-2002, 06:18 AM | #6 |
Were a distributor for M&H Wire, if you want wiring that appears exactly like original with original style ends and color coding to wire M&H wire is the way to go. Heres a link to our page with it
http://www.gmcpauls.com/Electrical.htm We can save you about 20% over standard retail through M&H. GMCPaul |
06-24-2002, 09:37 AM | #7 |
Thanks,
Paul,
I will be in contact with you when I get ready to get the harness. Its nice to have someone on the board that uses what he deals with and keeps a eye out for the good stuff
06-24-2002, 10:33 AM | #8 |
I also went with GMCPaul with no hiccups....Direct replacement.
Regards, Dewayne 70cst |
