07-20-2005, 10:12 AM | #1 |
Pesky transmission leak......
Well, without the "search function" hard to look this up and also to find my old thread----here goes:
Got a 84 C10 -w- modded 305 and a 350 trans....has had a pesky leak of transmission fluid from around the front of the yoke; rear of the trans where it connects to the driveshaft---replaced the rear seal twice, replaced the smaller "little known" yoke gasket as well (see here: .http://www.73-87.com/7387garage/drivetrain/yokeleak.htm ) ......seemed to stop my problem, but looked under there this morning---there is that pesky puddle again......any other ideas from the forum??? This is getting to be quite a nuisance.......!!
"Fighting for our freedoms....." |
07-20-2005, 10:35 AM | #2 |
Stepsides RULE
There's something with a dimple hole or something on the Ujoiont? the yoke? somewhere near there, there is a drain hole that when parked on a slope, leaks the fluid rather than whatever its supposed to do. Sorry i don't know exactly what it is, but there's a picture floating around of what it is.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
07-20-2005, 10:49 AM | #3 | |
07-20-2005, 11:08 AM | #4 |
also if you will look at the top of the screen... the search does work, it has been moved up higher than it was before....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
07-20-2005, 11:29 AM | #5 |
I Don't Know This At All But Could Your Problem Be The Fact That Your ( Yoke , Shaft What Ever You Call It) That Goes Into The Trans Is Maybe Shorter Than It's Meant To Be Or Its Too Long And Damaging The Seal You Keep Replacing Idon't Know But Kinda Makes Sence To A Shade Tree Mec. Like Me? P.s. I Have No Shade Tree Either
square body trucks an addiction or an investment either way they consume all my extra time and money |
07-20-2005, 11:34 AM | #6 |
I don't know either, but that makes sense too---I sure thought replacing that yoke weep hole gasket would do the trick----any other thoughts out there??
BTW, I must be a Barney Rubble or something....I cannot find that "search" button that is mentioned above.....previous post stated it was at the top.......
07-20-2005, 12:09 PM | #7 | |
Insert Witty Text Here
Could it be leaking at the speedo cable? Mine leaked from both, and I did not realize it was two leaks a first. The search is in the box at the top of the page that says "Google." Slonaker |
07-20-2005, 12:53 PM | #8 |
Sorry, misquoted myself....it was the "O" ring that was replaced as well as the rear seal (twice.....). If it is the speedometer gasket/seal, would it appear to be coming from the yoke/front of the driveshaft? It is dripping from there......overnight, it makes quite a puddle....
"Fighting for our freedoms....." Last edited by woody96; 07-20-2005 at 12:53 PM. |
07-20-2005, 02:50 PM | #9 | |
Slonaker |
07-20-2005, 12:06 PM | #10 |
Slots go on anything!
take the driveshaft out, and put a piece of cardboard in the inside of teh yoke. Sounds redneck, but that should stop your leak.
1974 Jimmy- 5.3/4L80e/NP241 |
