Old 07-21-2005, 04:55 PM   #1
tomatocity
tomatocity's Avatar
Drop Spindle Updrade
I have a 1971 frame with stock disc front suspension. I have been researching different vendors for 2.5" drop spindles and this is what I find. There are drop spindles that will lower and allow you to keep the stock upper ball joints and outer tie rod ends. Then there are the drop spindles that lower and upgrade the upper ball joints and outer tie rod ends to 73-87.
*What is your preference?
*Are there any problems with the upgraded drop spindles?
*Is there more that I should know?
*What parts would you recommend replacing when installing the drop spindles?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-21-2005, 05:03 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The "upgrade the ball joints" version are simply 73-87 drop spindles. They are much more common, as there are more guys building 73-87 trucks. That's 15 year span there. So, the vendors throw in the later ball joints and sell them as a kit.
I prefer the "use your stock ball joint" spindles that are specific to the truck model. I have run many pairs of Early Classic spindles with great results. I will continue to use them in the future too.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-21-2005, 06:36 PM   #3
Jaredm82
Active Member
Jaredm82's Avatar
just to let you know, I have some brand new threaded couplers to adapt 73-87 tie rod ends to your original steering linkage that I will sell you
Jaredm82 is offline   Reply With Quote
Old 07-21-2005, 06:43 PM   #4
screamin_c102
screamin_c102's Avatar
Jaredm82 sending PM
screamin_c102 is offline   Reply With Quote
Old 07-21-2005, 06:56 PM   #5
tomatocity
tomatocity's Avatar
Tell me more. Where are you in CA?
Old 07-22-2005, 06:30 AM   #6
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
hey jaredm82 i am interested in the adapters or let me know where to find them thanks
gostranger is offline   Reply With Quote
Old 07-21-2005, 06:37 PM   #7
Jaredm82
Active Member
Jaredm82's Avatar
hey tx, would you say that 73-87 spindles are generally cheaper? and also, you can get 3" spindles for 73-87 and they are about the cheapest ones too
Old 07-22-2005, 08:11 PM   #8
screamin_c102
Jared, let Tomatocity or gostranger have 'em, I'm gonna go a different route. Thanx again.....Bill
