Old 07-21-2005, 06:00 PM   #1
Primered_69
Primered_69's Avatar
Ac line aluminum galled - Any fixes or need to replace
I have the line coming out my condenser that is aluminum and the line has a steel fitting. The aluminum is galled enogh that it is leaking. Are there any fiexs for this or do I have to spend the 200 for a replacement one. (I have just replaced with a new compressor, accumaltor, and o ring last weekend.)
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 07-21-2005, 08:05 PM   #2
dennislbrooks
dennislbrooks's Avatar
depends
Most likely you will have to replace the condenser. This should be an o-ring fitting. Carefully remove the burr --clean with alcohol of your choice -- use epoxy or lab metal with a smooth finish. Let hardened thoroughly. If you have a hole clear thru thru line, find a friend with a TIG welder.
dennislbrooks is offline   Reply With Quote
Old 07-21-2005, 08:54 PM   #3
70short/step
70short/step's Avatar
Any Radiator shop that repairs aluminum should be able to fix it for you. I know the shop I used to work at does it!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
