Old 07-22-2005, 01:26 PM   #1
vtblazer
vtblazer's Avatar
Short bed 3/4 Ton?
I have a 2wd short fleet big block truck that I hope to use for towing/hauling.
Couple questions:
Can I just install 3/4 ton springs in the rear without issues popping up?
Should I also put some 3/4 ton springs up front when I do?
Both front and rear are coil springs.
I have additional questions also but their contingent on these answers first.
vtblazer is offline   Reply With Quote
Old 07-23-2005, 08:52 PM   #2
vtblazer
vtblazer's Avatar
Okay then, out of 24 views nobody seems to know the answer.
How about another one?
Is there such a thing as a 3/4 ton front Coil spring?
Old 07-23-2005, 11:48 PM   #3
orange72
orange72's Avatar
it seems to me that the 3/4 ton springs would be ok. prabably ride a little rougher though but your gonna use it for towing anyways.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 07-24-2005, 09:01 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I pm'd you but missed the coil rear.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-24-2005, 09:05 AM   #5
vtblazer
vtblazer's Avatar
returned the pm before I read this...
Explained all about the coil thing again.
Old 07-31-2005, 12:13 PM   #6
vtblazer
vtblazer's Avatar
3/4 ton coils seem to work great.
Towing a car hauler doesn't even make it squat anymore.
We'll find out how it is with a truck behind it when I go to NH to pick up jc's 3/4 ton lwb 4x4 Aug 7/8th.
Anybody need anything moved/hauled?
Traveling down empty.
One thing I did need to do was install a set of 3/4 ton shocks in the rear to get an exceptable return rate, the 1/2 ton shocks couldn't handle the new springs.
To sum it up...VERY worth while conversion.
