07-25-2005, 11:41 AM | #1 |
Door Seal Help Please
I installed new door seal rubber, good stuff, soft seal, my issue is I have to slam the door hard to get the door to catch. I have adjusted everything, any suggestions. Very disappointing.
Kenny |
07-25-2005, 11:48 AM | #2 |
I make Models
Weather stripping is new and not broke in.....try parking the truck with the door shut in the hot sun and see if it gets any better......Paul
07-25-2005, 11:52 AM | #3 | |||
Union Electrician
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
07-28-2005, 06:41 PM | #4 |
Orange Truck
Give it time as it will settle in eventually. I had the same problem.
07-28-2005, 07:28 PM | #5 |
Project Junkie! Fishing Poor!!
Just checking to make sure you have the hollow core with molded corners. Some companies sell solid core and no molded corners. Those will not ever break in..... WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-28-2005, 08:18 PM | #6 |
67-72 Addict!
Bill Athey gave me a neat bit of advice that helped. Take an ice pic and poke holes around the perimeter every 3"-4" to relieve some air. The rubber is compressed so you won't see these holes at all. I was worried before trying it but it worked good and it still took a few months for the seal to relax. Now they shut perfect. Before you always had to slam them HARD!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-28-2005, 10:19 PM | #7 |
Thanks to all, I have the soft seal, hollow inside, the doors shut but I have to slam them. To make matters worse, The D*mn door locks work fine when the door is open, when they are shut wont lock. Any suggestions.
Kenny |
07-29-2005, 07:19 AM | #8 |
Honestly it sounds like your door is out of adjustment---if the locks wont work when closed you have too much pressure on them is what Im thinking
