Quick 383 Balance Question..
I'm just about ready to build my 383 and I am going to mate it to my Muncie 4 speed in my '68 shortbed. I was wondering if anyone has used a 383 Balance Plate that bolts between the crankshaft and the flywheel? I am kind of weary on using such a thing, but dont really want to buy a manual flywheel for a 400sbc. Any opinions? Thanks!
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed -1968 Chevy SWB = numbers matching 307/Truck 4 speed. -1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC -1972 Chevy Nova = 2 door/412 Small Block -1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything. |
if the crank was balanced .....it should have had the fly wheel bolted to it to do it correctly !!!!!!
~Rest In Peace~
external balance should have the flywheel and clutch assy on for balancing
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
^ what they said! External balance is a little funny to deal with, you can swap flywheels a get a vibe on a stocker. I have seen guys use that balance plate, but i dont think its the best thing to do. If you havent assembled the engine.....best bet would be to take the balancer,crank, clutch cover & flywheel in to have it balanced together. that is the only way to make it truely "right on". best of luck......69L
http://community.webshots.com/user/hotrodhorn |
I'm going to balance the engine with the plate bolted to it. I think thats the idea of the plate, makes a 350 flywheel or flexplate into a 400 flywheel or flexplate sort-a-speak. Just wondering if anyone has used one before. Thanks for the info!
![]() Douglas.
