Old 07-27-2005, 01:36 PM   #1
'70_402
'70_402's Avatar
Internally regulated alternator..
What is a good year and model to get a internally regulated alternator off of? mid 80's chevy truck? just curious.
also can i just switch over to the internally regulated alt and just change the way it is wired up?
Rick
'70_402 is offline   Reply With Quote
Old 07-27-2005, 04:12 PM   #2
Mad Dog
Mad Dog's Avatar
1986 chevy celebrity= 100 amp alt....but you gotta change the pulley.
1978,79 chevy truck with a 454....big alternator that pushes 140 amps....just make sure it fits
72 C10 longbed 5/7 drop, Telstars, 350/th400(for now)
69 Chevelle SS396 (427/th400)
88 K5 on 35's (355/700R4/208)
Mad Dog is offline   Reply With Quote
Old 07-27-2005, 04:24 PM   #3
jescates
jescates's Avatar
I am not sure what year mine is, I just went in and told the counter guy that I was swapping over to an internal regulated alternator and he hooked me up. Showed me the different plug that I needed. Pretty easy installation, I know there is a way to jumper the original regulator and use the existing truck wires, but since I mounted the alternator on the passenger side, I bypassed the original regulator all together. I want to say I ran a hot wire straight from the battery to the Alt. and then since I had a dummy light instead of an amp guage, I just looked up the wires in the diagrahm for the dummy light and wired it up so if something went wrong, I would get the light. I used to have a website that showed the step by step process on an early Chevelle, it's the same for our trucks. I will see if I can find it again. Good luck.
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline   Reply With Quote
Old 07-27-2005, 04:29 PM   #4
jescates
jescates's Avatar
Here, check this site out. The second wiring diagram is pretty much how I set mine up and it works great!
http://www.novaresource.org/alternator.htm
1970 C-10 LWB
2009 Honda VTX 1300
2013 Buick Enclave
Old 07-28-2005, 06:11 AM   #5
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
I ordered this p/n from summit. SUM-811001 100 amps and bolts in original location. There is also a great write-up in the FAQ section about the wiring from external to internal reg. alternators. It took me 15 minutes max to do the whole thing.
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 07-28-2005, 06:15 AM   #6
phanatic32212
Here's a link to the FAQ:
http://67-72chevytrucks.com/vboard/s...9&page=1&pp=25
Or Give Me DEATH
