Old 07-27-2005, 04:51 PM   #1
bigunde
Rusty Rockerfeller
car trailer tire question
i have a car trailer that needs new tires,what the difference between the trailers tires or just putting regular tires on it?thanks
bigunde is offline   Reply With Quote
Old 07-31-2005, 09:58 PM   #2
Hart_Rod
Hart_Rod's Avatar
Nothing really, unless you are hauling extremely heavy loads. Then you might want to use higher ply tires.
Rob
Hart_Rod is offline   Reply With Quote
Old 08-01-2005, 07:45 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Rob
When I had my car trailer I put 175/50/15 tires on it, put the whole
set-up lower to the ground, easier to get lowered vehicles up on it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-01-2005, 09:31 PM   #4
rodnok1
rodnok1's Avatar
Construction is the main diff between them. I use "P" tires on pickups and trailers that don't see alot of weight(not on car trailers unless just running around town because they won't last). LT for Light truck seeing weight and towing. ST(special Trailer) for trailers used on highways and higher loads(car hauler). Then there are load ranges also of B C and D. Do not get Carlise tires for trailers..they are junk and blow all the time. You might want to check out the Rv site as they discuss tires constantly.
http://www.campingworld.com/cforum/index.cfm
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 08-02-2005, 03:58 PM   #5
BigDaddyCMU
You're best off going with an actual trailer tire. Trailer tires take a lot of side to side stress when turning and such, which car tires are not designed for. Trailer tires are also narrower, which helps by decreasing rolling resistance. You can usually find them for under $50 a tire.
BigDaddyCMU is offline   Reply With Quote
Old 08-03-2005, 08:47 PM   #6
72gord
Never enough time!!
72gord's Avatar
I built my trailer using mobile home axles...get the tires with rims from the local manufactured home seller for $30 a piece and can pick from the pile of about 25 to 30! The axles were $75 with brakes and $40 with out...bounces a little when unloaded but the price was right (as Bob Barker would say) LOL
72gord is offline   Reply With Quote
Old 08-03-2005, 08:50 PM   #7
bigunde
Rusty Rockerfeller
Thanks guys i bought 4 new trailer tires and they should be tommorrow
Old 08-03-2005, 11:26 PM   #8
GMC1tondually4dr
Moble home axles and tires are not to be used for towing.
They are for moving a moble home frome one place to the other, at low speed and very infrequently, like once or twice in the moble homes lifetime.
Just my .02
CCDually
GMC1tondually4dr is offline   Reply With Quote
Old 08-04-2005, 12:20 AM   #9
gmcracing92
Drillin oil on American Soil!
gmcracing92's Avatar
never use trailer house axles for car trailers, always use axles that we made to haul heavy loads all the time.
Travis
70 Chevy c20 2wd
75 Chevy k10 4x4 parts truck
92 GMC Sierra c1500 2wd DD
99 Chevy Reg Cab Sht Box 1500 2wd
05 GMC Sierra Denali white
gmcracing92 is offline   Reply With Quote
Old 08-04-2005, 08:16 AM   #10
72gord
Never enough time!!
72gord's Avatar
I don't travel too far from home and have never had a problem, btw a mobile home weighs way more than my trailer with a vehicle on it. If I were concerned safety wise I wouldn't have used them...safety always should come first in my opinion!!
Old 08-04-2005, 12:56 PM   #11
71swb4x4
71swb4x4's Avatar
I worked with a mobile home seller, and after we got a home set the axles were sent back to the factory so they could go under another trailer. I always thought that was how it worked for the most part. So those axles could sit under several homes every year.
I don't see any problem with using them.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
