Old 07-31-2005, 11:56 PM   #1
Blue82Chev
Murph
Fuel pump worries
I have a 1998 k1500 with a 5.7 and 110,000 miles on it. Every person I know with one of these trucks the fuel pump went out at about the same milage. I was thinking about replacing the pump now as a precaution before it goes out and leaves me stranded. What do you guys think?
Mike
Vehicles:
1982 C20
2003 GMC Sierra
Blue82Chev is offline   Reply With Quote
Old 08-01-2005, 05:36 AM   #2
If it makes you feel better, nothing wrong with that. Mine has 145,000+ and the pump is still working fine.
Old 08-01-2005, 07:03 PM   #3
driver64
driver64's Avatar
i beleive the main cause of these pumps going is that they over heat. if you let your tank run right down to empty the pump may over heat because it will no longer be submerged. i try to make sure to not let my tank go below a 1/4 tank, as to not overheat the pump. the only bad thing is if the pump does fail you have to drain all the gas out to change it. and thats a pain in the butt
driver64 is offline   Reply With Quote
Old 08-04-2005, 05:55 PM   #4
Very wise words there.. I was told mine was going, but that was 40 thousand miles ago. I keep my tank at least quarter full all the time, normally over half. Like driver64 says if they are unexposed alot, they burn up quicker. The tanks should always keep them submerged, but sometime defects allow the featuer to let the gas drain from around it.
Old 08-05-2005, 09:43 AM   #5
Jake Wade
Jake Wade's Avatar
I have 171,000 on the original pump in my '95. I install a new fuel filter every 15 to 20,000 miles and never run below a 1/4 tank. I plan on replacing the pump and strainer with AC-Delco at 200K if it does'nt go out before then.
Jake Wade is offline   Reply With Quote
Old 08-03-2005, 09:12 PM   #6
partsman9606
a country boy can survive
partsman9606's Avatar
i say leave well enough alone!!
partsman9606 is offline   Reply With Quote
Old 08-04-2005, 06:55 AM   #7
Crank
Crank's Avatar
Mine had about 90 grand on it when it died. But it was feeding a '98 4.3L 2wd... But you've surpassed me by far, sometimes they just do that, and sometimes they just fall on their faces.
Brandon
Crank is offline   Reply With Quote
Old 08-04-2005, 07:49 AM   #8
papawswrench
Replace it when it stops whining !
papawswrench is offline   Reply With Quote
Old 08-06-2005, 02:58 AM   #9
jolee
Have you guys ever heard of a fuel pump that sounds like its working (humming) but is not providing enough pressure to start the truck? (96' 350 vortec in a 1/2 ton 4x4) mines acting up i think....wont stART but it i can hear a humm but it doesn't sound normal?????.....I changed it 30,000 miles ago.....
jolee is offline   Reply With Quote
Old 08-09-2005, 03:24 PM   #10
jolee
Fixed my truck ...it was the fuel pump! ...it humms and provided enough pressure when cranking that the the fuel pressure tester said it was ok!!!! Pulled it out, and put in a new GM pump,.. problem solved...Weird eh? the pump Ohms out just fine at 1ohm....but DOES NOT WORK!(well enough to provide "running Pressure".
-Just something to think about when you have a problem..
Jolee.
Old 08-09-2005, 05:28 PM   #11
gene_champ
on my 96 k1500, fuel pump went out at 89k. it still ran, but pump was not always putting out enough pressure. i got it replaced before it quit completely. pump, sender, labor was a 600.00 deal.
1949 chevy 3100, 5 window
1992 chevy k1500, extended cab, short box 5.7l
1996 chevy k1500, extended cab, long box 5.7l
2001 chevy impala ls 3.8l
1965 honda s90
gene_champ is offline   Reply With Quote
