Old 08-01-2005, 09:53 PM   #1
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Question Question for people who know exhaust!
Hi all,
First off, I must say, my truck has never been all that loud. This is not to say that this is on purpose . The truck has had dual exhaust since the get go, first 1 7/8 now 2 1/4, and 3 different types of mufflers from glasspacks, to cheapy turbos, to now Flowmaster 40 series Delta flows.
My beef is mostly with the sound at idle...it's just too quiet. The engine is quite mild, so far it's just a 350 4-bolt main, edel 1406 carb, HEI ignition, edel performer aluminum intake and corvette style ram horns. At idle is it very mellow, no lump at all and yes it has a wussy cam, but still...I have seen other cars with the Exact same setup that sound a lot lumpier at idle and I don't mean cam lumpy, just the sound of hearing every cylinder fire basically, mines just one steady mellow "flow" of sound.
Can anyone tell me why this would be? I was thinking that it might be due to low compression maybe? Like being that each cylinder doesnt explode at strongly it's just mellow?
I know this sounds kinda funny, but basically what I'm asking is what makes exhaust louder? (other than straight pipes) Because even with the old blown out glasspacks it was not really loud at all...
you thoughts???
thanks
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 08-01-2005, 10:10 PM   #2
hilljob26
hilljob26's Avatar
are you running headers or manifolds
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-01-2005, 10:13 PM   #3
tripp
exhaust
i think it may be because you're using the ramhorn manifolds. i've noticed on my trucks that everything that has cast iron manifolds has a more mellow less aggressive sound. on my '72 fleetside, i have a basically stock 283 with 305 heads and an "rv" cam with full length headers and 40 series flowmasters and this thing at idle sounds like it will eat your lunch. you may want to try some sort of header. my .02 worth.
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 08-03-2005, 02:00 PM   #4
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
This may be true.I'm running ramhorns with 2 1/4 pipe with glasspacks that end right at the back of the cab,and it's not all that loud.This is basically the same length as a header muffler.My brothers 72 with headers,and 2 1/4 pipe and turbos at the diff is louder.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 08-01-2005, 10:16 PM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
Having a relatively mild duration on your cam will keep it quiet and 2.25" pipe is quiet as well. It's perfect for your cam but is really quiet in comparison to 2.5" pipe. Wher does your exhaust terminate?. The shorter the louder.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 08-01-2005, 10:22 PM   #6
matthufham
big pipes, short distance, less bends, big tip, performance muffler, and free flowing exhaust manifold or headers all = more sound. also consider exit location for determining how loud, inside the cab with exhaust turning down at the rear is quieter than side pipes
matthufham is offline   Reply With Quote
Old 08-01-2005, 10:54 PM   #7
bowtie
bowtie's Avatar
Sounds like you have a finely tuned engine.
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
Old 08-01-2005, 10:55 PM   #8
MandarinSixSeven
Seasonal Poster
I kind of thought it would be because of the manifolds, someday I do plan to get some sort of headers, but I want to wait until I can totally re-do the engine.
As far as exit location, it was exiting in front of the rear wheel until about a month ago, now it's behind. That, I know made a huge difference in the cab, I actually like that its quieter in there now, and extending the pipe changed the sound, but really the volume...
Oh well, I thank you all for answering my question...someday it will be LOUD!
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-02-2005, 12:18 AM   #9
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
No tailpipes behind the mufflers....It will be loud and mean then
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 08-02-2005, 11:19 AM   #10
MandarinSixSeven
Seasonal Poster
lata
CHRIS
This is true. The thing is, even when I had tailpipes in front of the rear tires it was super loud inside, but nothing crazy outside.
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-02-2005, 03:48 PM   #11
paintpyro
paintpyro's Avatar
Haha, thats what I have, and yes, its loud
lata
CHRIS
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 08-02-2005, 11:31 AM   #12
farside847
farside847's Avatar
Im kinda partial to the mellow idle myself (yes, I have manifolds with a dual 2.25 pipes exiting behind the wheels)
It kinda sits there, peeerrrrrring. Then at a grean, it GROWLS and makes everyone look
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 08-02-2005, 11:57 AM   #13
Johns70
Johns70's Avatar
compression ratio has a lot to do with it.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 08-02-2005, 12:12 PM   #14
wolfthing2000
Just enjoy the peace and quiet! Horsepower doesnot have to be loud.
wolfthing2000 is offline   Reply With Quote
Old 08-02-2005, 12:12 PM   #15
71-longbed
Its Magically Delicious
71-longbed's Avatar
is your truck a daily driver ??? attention is nice when your driving but not when its the fuzz
im running ramhorns with dual glasspacks that exit behind the rear wheel .. mines alittle loud but not at idle .. only when i press the go pedal .. but glasspacks dont give off the rumble that most people like ....
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-02-2005, 12:43 PM   #16
'70_402
'70_402's Avatar
It is because you go the delta flow 40 series... there is a big diffence between the delta's and the regular two chamber flows... i mean BIG difference.
'70_402 is offline   Reply With Quote
Old 08-02-2005, 12:55 PM   #17
MandarinSixSeven
Seasonal Poster
Reeeeeally? I knew there was a difference, but I didn't know there was a BIG difference. But now that you mention it, my friend just took off some 40's because they were too loud, I never put 2 and 2 together and thought of that.
Damn, I should have grabbed those off of him when I had the chance...Although really, I do like the sound of mine, I just wish there was more of it
So, does this mean that the delta flows are not 2 chambers?
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-02-2005, 03:39 PM   #18
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Even though I hate FLOWS, used to install em, never will own em again
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-02-2005, 02:59 PM   #19
72MARIO
72MARIO's Avatar
Go Super 40's. I have them in my 3" system and the sound awesome.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-02-2005, 03:15 PM   #20
'70_402
'70_402's Avatar
super 40's have the delta flow technology also.
Old 08-02-2005, 03:48 PM   #21
MandarinSixSeven
Seasonal Poster
Well, even though I HATE excessive emoticon use, people still use them - to each their own...thanks for the useless post.
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-02-2005, 03:51 PM   #22
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Wansn't useless, I was reafirming what was said about the differance in the
flows, they do sound dramitically different, I'm sorry that you feel that way.
My reply was based on the fact that I worked at a muffler shop for 2.5 years
Old 08-02-2005, 03:53 PM   #23
MandarinSixSeven
Seasonal Poster
My Bad...
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-02-2005, 04:00 PM   #24
'70_402
'70_402's Avatar
My Bad...
haha I love flows just not a big fan on the delta flow technology.
hey mandrin, i have a few videos of what mine sounds like for some reference. i can't post vidoes but i can email them to ya.
i have 2.5" mandrel bent pipe with regular 40 series flows dumped after the muffler.
Old 08-02-2005, 04:12 PM   #25
kxmotox247
kxmotox247's Avatar
Whatever you do, don't get the small drag race 1 chamber mufflers that flowmaster makes. I have them on my 67 with a very similar motor. The exhaust dumps in front of the diff. and it's relatively quiet at idle but sounds like crap once you throttle it.
These were put on by the previous owner. Louder is not neccesarily any better. Those mufflers make it sound like the truck is one giant exhaust leak.
kxmotox247 is offline   Reply With Quote
