Old 08-04-2005, 05:21 PM   #1
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Sandblasting spindles
I know you can't sandblast the part of the spindle were the brake disc goes on but I was wondering if I cover that part up if it would be alright to sandblast the rest of the spindle. I wan't to have all my suspension pieces sandblasted, sprayed with primer and painted black, so if there is anything else I should know about the other suspension components before I start doing it this weekend.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 08-04-2005, 05:39 PM   #2
ed455
Captain Ed
Yep, blast away.
ed455 is offline   Reply With Quote
Old 08-04-2005, 06:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Use duct tape to cover the spindle.
Old 08-04-2005, 06:58 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-04-2005, 07:17 PM   #5
GloryHound
Working on a Nova.
GloryHound's Avatar
might want to plug were the balljoints and tierod slip on that is a machined surface also.
GloryHound is offline   Reply With Quote
Old 08-05-2005, 02:38 AM   #6
edmonton72
edmonton72's Avatar
Thanks. I got to find out wut is wrong with my sandblaster, it wasn't working today. Maybe I should drain out the old sand and put in new stuff. It has been only sitting in there for three days put i collects moisture in there because i have a pretty funky compresser setup. The tank is and old propane tank the we convert to work as a holding tank for the compresser and sometimes the air still smells like propane.
1972 C10 Longbox
Old 08-05-2005, 02:40 AM   #7
edmonton72
edmonton72's Avatar
Is there anything else i should mask off. Also is it hard to replace the ball joints and rubber bushings.
1972 C10 Longbox
