distributor question
I have a 68 with a 327 and the original distributor and mechanical points. Can anyone recommend a replacement distributor with electronic ignition that a rookie could easily install? Not looking for high performance at this point. Thanks
its all about the +6 inches
A stock junk yard HEI is pretty hard to beat. If you look around a bit, you'll find one with a new module, coil, cap and rotor. PPl will try to tune up a car to get it running and then tow it to the junk yard once they run out of cash and give up. I bought at least a dozen like so in the last few years. Heck, I got a junk yard HEI for my caddy 500 with an accell super coil on top, and a brand new set of accell wires to...all this for 20 buck.
You just can't go wrong there. Simple to wire, it's almost as easy as a simple remove and install. Look on the FAQ page, there are a couple write ups on this. |
I just put one in the 283 in the 67. It sure made a difference. Of course it would since the mechanical advance mechanism was rusted together and would not advance. I gave $30 for dist, cap, and a pretty decent set of wires.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
looked at the FAQ's on HEI and got a ton of info. Thanks. I'm off to the junk yard!
item number 2 on parts board
http://67-72chevytrucks.com/vboard/s...04#post1358604 Last edited by rage'nrat638; 08-07-2005 at 09:57 PM. |
