Help ID this Holley
I have decided to use the Holley that came with the truck. I have attached some pics so I can get help IDing (model number) the carb. I was hoping to add a spring bracket that mounts from the carb. Thanks in advance.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. Last edited by tomatocity; 08-08-2005 at 03:00 PM. Reason: text |
600 holley carb....
vacuum secondarys.... manual choke...... good carb.....won't pass emmissions with it ....if you have to test,,,,,, ![]() |
C10 now is a GMC
I'm running the same carb, it's a 600CFM.
![]() ![]() ![]() David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
Those numbers stamped on the front of the air horn should give you all the info. Write em down and show em to the parts guy for the correct rebuild kit.
Thanks for the information. I updated my post. Do you know the Holley model number?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
the model # is the # on the air horn.
It is a 1850 and I found the part number for an electric choke. Thanks everyone.
Having issues
The "type" of carb is a 4160. I have about 8 of these turkeys laying around in my garage, if you are ever in my neighborhood, I could give you one you could use for parts to convert to an electric choke. As far as the spring bracket is concerned, kragen carries a package of them that has an assortment of them. I say just loop the spring into one of the various holes and call it good. Why spend $8 on 10 studs you will not use?? :P
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
