08-08-2005, 08:47 AM | #1 |
Column shift question
My poor truck has a column shifter, a clutch pedal, and some kind of Oldsmobile looking floor shifter.
I'm guessing it was a 3 on the tree originally, but it has a TH350 connected to the floor shifter. Eventually I'll throw in a auto overdrive tranny, but for now I just want to hook up the column shifter. Does anybody know what I need? I'm guessing the column and shifter aren't specific to either manual or auto? Thanks, Chris Last edited by mplex2000; 08-08-2005 at 08:48 AM. |
08-08-2005, 10:04 AM | #2 |
Column shift parts
You will need an auto column, the linkage to the trans as well as the pivot bracket and trans bracket. OR...you can get an aftermarket linkage set up for like $50 that works great. I have it on my 71. I can post pics when I take them. I have the link to the place somewhere.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
08-08-2005, 10:53 AM | #3 |
Thanks for the info! I had seen a couple of linkages, one was from Lokar I believe. The other is this one:
http://www.bowtieoverdrives.com/cata...php?ITEMID=193 Is that what I need? Thanks!! |
08-08-2005, 10:53 PM | #4 |
im currently useing a lokar kit on my 700r4, it was an easy bolt on 20 minute project.
08-09-2005, 11:20 AM | #5 | |
The 3 on the tree had linkage that connected to the column under the hood and went under the truck to the trans. Im guessing the linkage was removed when the floor shifter was put in. If you want to go back to stock and use the 3 on the tree, you will likely need new linkage and bushings. I bet you can get a set pretty cheap on the parts board.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
08-09-2005, 11:40 AM | #6 |
So I can't use this column (originally 3 speed manual shift) with an automatic tranny?
08-09-2005, 11:46 AM | #7 | |
